Need PCM/ECM info #2505371
06/06/18 08:49 PM
06/06/18 08:49 PM
California
H
HemiCJ Offline OP
HemiCJ  Offline OP
H
California
Hello,
I hope I can get some info here. I have done a general search and didn't come up with any results. Actually I have been looking for a several months.
Here is the story: I have a 2013 5.7 Hemi from a 2500 Ram 4X4 with a 66Rfe trans. I have the engine wiring harness, computer, APPS, fuse block, and a few other goodies. I have mounted it into an '83 CJ7. I have figured out the fuse box, mainly because its labeled. What I don't have and haven't found yet is the computer pinout to connect the apps and find the data port. The computer p/n is P68089649AC
Any help would be appreciated.
Rick
2015 Ram 1500 Ecodiesel
2015 Grand Cherokee Ecodiesel
2010 Jeep Patriot
1951 Ford F1 w/Stroked 340 Six Pack
1983 Jeep CJ7
Re: Need PCM/ECM info [Re: HemiCJ] #2505493
06/07/18 07:46 AM
06/07/18 07:46 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
This is the best I can do for you, you'll have to spend sometime digging thru, but the Info you seek should be in there.
http://connectors.dcctools.com/home.htm
Re: Need PCM/ECM info [Re: ric3xrt] #2505526
06/07/18 11:03 AM
06/07/18 11:03 AM
California
H
HemiCJ Offline OP
HemiCJ  Offline OP
H
California
THANK YOU VERY MUCH! This looks promising.
update, FOUND IT! I searched on-line for months and it took me about 10 minutes with this link. The fabrication is almost done, now I have a good chance of actually getting it running.
2010 Jeep Patriot
1983 Jeep CJ7
Re: Need PCM/ECM info [Re: HemiCJ] #2505668
06/07/18 06:14 PM
06/07/18 06:14 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I love it when a plan comes together.
Re: Need PCM/ECM info [Re: HemiCJ] #2510004
06/18/18 02:27 PM
06/18/18 02:27 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I used alldatadiy when I didnthr magnum swap in my jeep. Pretty helpful
