Alternator to cylinder head: How close is too close?
#2500167
05/25/18 12:41 AM
05/25/18 12:41 AM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
Hi all,
I'm adding a Sanden a/c compressor to my 440, so I'm currently mocking it up. In order to get the alternator pulley to line up with the (Bouchillon #4013) crank pulley, my alternator needs to move toward the rear, maybe 3/8" to 1/2" from where it currently is. If I do this, it will be approximate 1/8" to 3/16" from the right cylinder head. Is this too close? I'm concerned about heat damaging the alternator. Do I need to worry? Thanks for any opinions or suggestions.
Roger
Re: Alternator to cylinder head: How close is too close?
[Re: Fab64]
#2500200
05/25/18 07:23 AM
05/25/18 07:23 AM
Posts: 5,748 ohio
ruderunner
ohio
Heat won't be the problem. Adjustability and clearance for the terminals will be.
Angry white pureblood male
[Re: Fab64]
#2500209
05/25/18 08:05 AM
05/25/18 08:05 AM
Posts: 4,701 Florida
BDW
[Re: Fab64]
#2500315
05/25/18 02:38 PM
05/25/18 02:38 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Not a problem, the head only gets to 200 degrees or so.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: ruderunner]
#2500324
05/25/18 03:17 PM
05/25/18 03:17 PM
Posts: 2,254 IL
furious70
IL
Heat won't be the problem. Adjustability and clearance for the terminals will be. +1 just make sure the batt lug can't come in contact with the block if the bracket flexes under load.
[Re: furious70]
#2500497
05/25/18 11:05 PM
05/25/18 11:05 PM
& if you do ever have to space an alt forward, crank/wp shims are commonly available
[Re: Fab64]
#2500551
05/26/18 02:58 AM
05/26/18 02:58 AM
440source has nice ones for the crank (probably for the pump too) & I have used chebby ones for the pump & not sure if I had to elongate the holes or not (no iirc) & I'm sure WP pulleys for us are out there & I've even used washers tho full support is way better. finding the correct depth pulleys for alignment is a real challenge (& the ratio does come into play).
[Re: Fab64]
#2500590
05/26/18 09:34 AM
05/26/18 09:34 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
