A body 8 3/4 axle shaft won’t come out #2498707
05/21/18 06:16 PM
05/21/18 06:16 PM
British Columbia, Canada
3
340Forrest Offline OP
Hey everyone I got a 69’ Dodge Dart parts car that has a 3.91 489 sure grip that I want out of it. Pulled the drivers side axle no problem at all, passenger side will not come out, been at it for hours, resorted to beating on it with a hammer, 5 ft pry bar etc, all 5 nuts are off, it looks like the bearing is packed with dirt, sand from the sandblaster and rust, any recommendation on how to get it out? I just want this carrier!!! Thanks in advance, I’ve never had this issue with any of the other 8 3/4s I’ve done.
Re: A body 8 3/4 axle shaft won’t come out [Re: 340Forrest] #2498719
05/21/18 06:29 PM
05/21/18 06:29 PM
RapidRobert Offline
RapidRobert  Offline
put the drum on backwards with the lug nuts on backwards just enough so the stud(s) threads are flush with the end(s) of the nuts & use it as a slide hammer.
Re: A body 8 3/4 axle shaft won’t come out [Re: 340Forrest] #2498721
05/21/18 06:33 PM
05/21/18 06:33 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Maybe borrow a slide hammer from a friend or do the loaner tool from a parts house. Being a retired tech I have my own. wink
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: A body 8 3/4 axle shaft won’t come out [Re: 340Forrest] #2498724
05/21/18 06:39 PM
05/21/18 06:39 PM
Kirkland, Washington
Pacnorthcuda Offline
You've sprayed the rusty bearing areas with a lube right?
Re: A body 8 3/4 axle shaft won’t come out [Re: 340Forrest] #2498725
05/21/18 06:41 PM
05/21/18 06:41 PM
Since the drivers side axle is out, shove a broomstick in until it bottoms out against the pass axle end and give it a whack.
Edit.....forgot about the thrust button, this won't work
Re: A body 8 3/4 axle shaft won’t come out [Re: 340Forrest] #2498730
05/21/18 06:51 PM
05/21/18 06:51 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Got one to jump out by putting drum on until it leaves 3 or 4 lug nut threads sticking out through drum. Then put 2 different 1/2 inch pry bars between backing plate and back of drum, then spun a couple lug nuts on opposing studs, couple turns at a time, kind of using a puller effect to pull axle out. Worked for me.
Re: A body 8 3/4 axle shaft won’t come out [Re: 340Forrest] #2498731
05/21/18 07:00 PM
05/21/18 07:00 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
tie a cable to the reversed brake drum, or wrap with cable around drum
tie cable to 4x4
drive away FAST with a BIG jerk. (that is a 'tug', not an idiot in the 4x4 with you lol )
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: A body 8 3/4 axle shaft won’t come out [Re: amxautox] #2498783
05/21/18 09:22 PM
05/21/18 09:22 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
^ I could imagine a car falling off axle stands here.
Has this axle seen slicks? Spline could be twisted.
Re: A body 8 3/4 axle shaft won’t come out [Re: Magnum] #2498790
05/21/18 09:37 PM
05/21/18 09:37 PM
amxautox Offline
amxautox  Offline
OH YA!
Tom
author unknown
Re: A body 8 3/4 axle shaft won’t come out [Re: 340Forrest] #2498827
05/21/18 10:59 PM
05/21/18 10:59 PM
RapidRobert Offline
RapidRobert  Offline
I just want this carrier.
& when we get it out I wanna buy the housing from you.
Re: A body 8 3/4 axle shaft won’t come out [Re: 340Forrest] #2498894
05/22/18 01:24 AM
05/22/18 01:24 AM
I would try putting some heat on the housing at the axle bearing end while someone else pulls on it, maybe jerk on it with a chain attached to one stud with a nut, or use a loop in the chain attached to two lug studs with nuts and jerk on it several times scope
I've used that method more than once with only the chain, on your deal with rust in the housing bore I would try and use the heat to loosen the rust and then jerk away wrench
Re: A body 8 3/4 axle shaft won’t come out [Re: 340Forrest] #2498898
05/22/18 01:37 AM
05/22/18 01:37 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Just got a stubborn axle out of an early 8-3/4 (tapered axle). 5 lb slide hammer didn't budge it. I thought about many ways to get the axle out and finally decided to drill a hole in the top of the housing end and attempt to crack the outer race. I couldn't crack the race, but I was able to get the race to move with an air chisel with a pointed tip. I'll just weld the hole back up and rough machine it. Turns out the housing end has been welded on before, around the radius...
Re: A body 8 3/4 axle shaft won’t come out [Re: 340Forrest] #2499058
05/22/18 02:23 PM
05/22/18 02:23 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
You can see if the roll pin is sheared on the thrust button. Slide a magnet on a stick pull out the half of the thrust button and put rod through the button hole and wack it.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: A body 8 3/4 axle shaft won’t come out [Re: 340Forrest] #2499234
05/22/18 10:22 PM
05/22/18 10:22 PM
Maryland
MoparMike1974 Offline
Maryland
If that is a real 8 3/4 A body housing you should find a good home for it. I see people selling bare housings for $300-$600 and they are getting really hard to find.
Put a chain around the leaf spring/axle housing on the side without the axle and chain it to a tree. Then put a come-along ratcheting winch on the problem axle. Take all the slack out of the cable and then put some tension on it. Next tap the axle outward with a deadblow hammer or regular hammer. It shouldnt take much effort to get it to move. After a couple hits check the tension and tighten if needed.
Re: A body 8 3/4 axle shaft won’t come out [Re: 340Forrest] #2499433
05/23/18 12:24 PM
05/23/18 12:24 PM
Alberta
rustbuckett68 Offline
Alberta
I got a sure grip from a truck at the local self serve that acted like that. Limited tools, so I grabbed the driveshaft, got lined up under the car, and speared the backing plate a couple of times. Popped loose. It was the heaviest and handiest thing I could find. Not the easiest thing to do, but it worked.
Re: A body 8 3/4 axle shaft won’t come out [Re: MoparMike1974] #2499752
05/23/18 11:42 PM
05/23/18 11:42 PM
RapidRobert Offline
RapidRobert  Offline
I agree, I will provide a very good home for it, lots of love & nurturing .
