Re: Dana 60 602957 3?
[Re: AndyF]
#2497937
05/19/18 06:27 PM
05/19/18 06:27 PM
Posts: 25,729 Rio Linda, CA
John_Kunkel
You're correct on the date.
[Re: BDW]
#2498113
05/20/18 03:27 AM
05/20/18 03:27 AM
John_Kunkel
Probably a design upgrade that might not be obvious.
[Re: cudaman1969]
#2498393
05/20/18 09:51 PM
05/20/18 09:51 PM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
The previous owner of the Dana under my Savoy welded ladder bar mounts right at the end of the numbers It was drag car since about 1973 so that is how things were done back then. It was a 67 Camaro with a high winding 292 small block and a Nash 5-speed. Gus
[Re: fourgearsavoy]
#2498528
05/21/18 08:27 AM
05/21/18 08:27 AM
Posts: 4,704 Florida
BDW
The previous owner of the Dana under my Savoy welded ladder bar mounts right at the end of the numbers It was drag car since about 1973 so that is how things were done back then. It was a 67 Camaro with a high winding 292 small block and a Nash 5-speed. Gus Same here, got my original 4:10 E-body rearend out of my buddy's race Camaro. It had welded ladder bars and a 5:38 spool, only paid $300 for it, so I didn't mind cutting off the ladder bars and putting the original 4:10 gear set he had saved back in it.
