04 dodge , cummins no crank
#2497430
05/18/18 02:13 AM
05/18/18 02:13 AM
rowin4
Went down to the hardware store, came back out , turned the key, nothing. got dash gauges,dings when the key is on , lights. Turning the key to start nothing changes, no dimming, no clicks. Got it towed home. Figured it was the ignition switch , changed out the electrical unit. Nothing changed. Good batteries , clean and tight cables, could the starter just stop working????? but there is no draw on the system when the key is turned to start. Where to look next?
Re: 04 dodge , cummins no crank
[Re: rowin4]
#2497455
05/18/18 05:55 AM
05/18/18 05:55 AM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
Auto or stick? Does it have anti theft?
[Re: rowin4]
#2497489
05/18/18 11:44 AM
05/18/18 11:44 AM
rowin4
It's a auto trans. anti theft ? right now I wish someone would. If your talking about the key thing , no. Same key since new.
[Re: rowin4]
#2497544
05/18/18 01:56 PM
05/18/18 01:56 PM
rowin4
checked all the fuses in the fuse relay box under the hood, starter wire tight, ?????? Need to check connections under the fuse / relay box
[Re: rowin4]
#2497707
05/18/18 09:57 PM
05/18/18 09:57 PM
rowin4
Well I have some good news and some bad news. The good news is I got it started and running, the bad news is I don't know what I did to make it start. I swapped around a lot for fuses, relays everything that had anything to do with the start and run sequence. I opened and closed a bunch of plugins, looked at a lot of wires, didn't find any corrosion anywhere. I even pulled the starter and had it checked , still nothing. Then after some more probing it started and runs. This makes me a little leery as if it happens again i'll be out in the middle of nowhere with no idea of what to look for again. Thanks for everyone for your input
