Re: Maximum CR open chamber iron heads no quench- pump gas
[Re: domingo]
#2497280
05/17/18 05:53 PM
05/17/18 05:53 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
From my experience with PING monsters in hot Southeast Texas, I would go 9to1 I built my alum head 512 with quench at 9.7, just to be on the safe side.
[Re: domingo]
#2497291
05/17/18 06:08 PM
05/17/18 06:08 PM
Posts: 4,206 New York
polyspheric
There is much more going on in the chamber that changes with quench, including valve shrouding, squish turbulence, etc. Even if your quench distance is beyond conventional limits (best before .060", gone at .125"), having the surfaces approach each other to a closer distance at some points (a hemi does not) always helps. 1/2 point isn't worth 2%.
Boffin Emeritus
[Re: domingo]
#2497375
05/17/18 10:48 PM
05/17/18 10:48 PM
crabman173
crabman173
[Re: domingo]
#2497479
05/18/18 10:55 AM
05/18/18 10:55 AM
polyspheric
Overlap doesn't reduce CCP (later intake closing does), but reduces knock slightly because of residual exhaust gas - less power. This will vary with local exhaust port pressure, and system backpressure.
Boffin Emeritus
[Re: domingo]
#2497592
05/18/18 04:43 PM
05/18/18 04:43 PM
polyspheric
Opening the exhaust early subtracts from the duty cycle (less energy turned to crank rotation, more lost in the pipe) in favor of reduced pumping loss. Closing it later (during OL) leaves more exhaust gas in the chamber, which both dilutes and heats the new charge. Typically cylinder pressure is higher than we want (I want zero!), so the exhaust forces the new charge backward until RPM is higher (with high vacuum this is even worse). This is one reason why "split overlap" (equal duration IO BTDC and EX ATDC) is nothing like equal events in terms of pressure balance. Again, it's a compromise like everything else.
Boffin Emeritus
[Re: jwb123]
#2497684
05/18/18 08:42 PM
05/18/18 08:42 PM
Posts: 4,457 Washington
madscientist
Washington
Its hard to get a tight quench with open chambered mopar heads. If you measure them you may find the chambers are not as equal as you might think both volume and height. Octane needs of the engine have more to do with dynamic compression than static compression. I use an engine program to decide what kind of fuel the engine will need. Performance trends, it calculates cranking compression, advance curve, and lets you try different octane fuels. It also calculates a ton of other stuff. Results on a real dyno are close if you take the time to put good numbers in the program. And it costs about what a good 1/2 ratchet costs. It's not hard to get quench. Stick the piston out of the bore.
[Re: domingo]
#2497694
05/18/18 09:09 PM
05/18/18 09:09 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Cast Iron Heads.
Sea Elevation.
I think Im gonna play it safe and stay around 9:1
On an engine like this which should be putting around 500 hp (small block stroker with w2 heads). Each point increase in compression would equate to how much HP gains? Lets say if the engine made 500hp at 9:1 if it was bumped to 10:1 and race gas was used so it doesnt ping....how much HP would be gained from the full point increase in compression? There was a test on a 440 stacking gaskets to controle cr and from 9 to 1 to 10 to 1 gained 20 hp so maybe you would get 15hp.
[Re: domingo]
#2497712
05/18/18 10:25 PM
05/18/18 10:25 PM
polyspheric
I think he's referring to the "as cast" 452 etc. chambers in which the exact depth and especially the contour of the quasi-quench surface is irregular. The KB instructions begin with "mill this down until all 8 match".
Boffin Emeritus
