Master cylinder mounting #2496342
05/15/18 11:02 AM
05/15/18 11:02 AM
Loves Park, IL
H
HotRodRailroader Offline OP
H
Loves Park, IL
I need to know where to get the master cylinder studs and the plastic spacer for the master cylinder to firewall. I'm not sure what it is even really called. Car was power but now going manual brakes. I know the manual cars had them. Thanks in advance!
Re: Master cylindercylinder mounting [Re: HotRodRailroader] #2496346
05/15/18 11:15 AM
05/15/18 11:15 AM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
The "spacer" is a firewall reinforcement for the master cylinder. What year and model are you looking to do this on? I'm looking to upgrade my 1972 B-body to power disc brakes. Maybe we can work out a swap?
No longer taking $h!t from anyone!
Re: Master cylindercylinder mounting [Re: HotRodRailroader] #2496348
05/15/18 11:17 AM
05/15/18 11:17 AM
Loves Park, IL
H
H
Loves Park, IL
I should have added this is for a 1969 plymouth roadrunner. Not sure if they are the same or not.
Re: Master cylindercylinder mounting [Re: HotRodRailroader] #2496349
05/15/18 11:19 AM
05/15/18 11:19 AM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
i have nos and used studs
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: Master cylindercylinder mounting [Re: HotRodRailroader] #2496357
05/15/18 11:26 AM
05/15/18 11:26 AM
Slantytown
DUFFMAN Offline
DUFFMAN  Offline
Slantytown
I used to have a reinforcement from a 1968 B-body. I can look for it when I get home.
Re: Master cylindercylinder mounting [Re: HotRodRailroader] #2496360
05/15/18 11:31 AM
05/15/18 11:31 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
FYI,
there was no plastic spacer on manual brake cars.
master cylinder bolts directly to the firewall plate with a white foam gasket between them
Re: Master cylindercylinder mounting [Re: gtx6970] #2496376
05/15/18 11:45 AM
05/15/18 11:45 AM
Slantytown
DUFFMAN Offline
DUFFMAN  Offline
Slantytown
Originally Posted By gtx6970
FYI,
As far as I know there was always a steel reinforcement plate installed between the master cylinder and the firewall on manual brake cars. I know my 1972 B-body has one.
Re: Master cylindercylinder mounting [Re: HotRodRailroader] #2496382
05/15/18 11:57 AM
05/15/18 11:57 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think Dr Diff sells a reinforcement plate.
68 Barracuda Formula S 340
Re: Master cylindercylinder mounting [Re: DUFFMAN] #2496406
05/15/18 12:42 PM
05/15/18 12:42 PM
Loves Park, IL
H
H
Loves Park, IL
That would be great!
Re: Master cylindercylinder mounting [Re: DUFFMAN] #2496416
05/15/18 01:09 PM
05/15/18 01:09 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
FYI,
There was always a steel re-reinforcement plate behind either the booster or master cylinder. Be it manual or power brakes - drum or disc ( plates were different for each individual application.)
The only 'spacer ' was on power drum brake applications. Even then it was a combination of plastic and aluminum.
Re: Master cylindercylinder mounting [Re: HotRodRailroader] #2496503
05/15/18 03:36 PM
05/15/18 03:36 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
http://www.doctordiff.com/70-74-mopar-b-e-body-firewall-stiffening-plate.html
Re: Master cylindercylinder mounting [Re: HotRodRailroader] #2496575
05/15/18 07:26 PM
05/15/18 07:26 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I have a few of those "manual" plates kicking around. Drop me a PM.
Re: Master cylindercylinder mounting [Re: HotRodRailroader] #2551592
09/18/18 05:34 PM
09/18/18 05:34 PM
Loves Park, IL
H
H
Loves Park, IL
Ok I've been busy and now I really need this part. I need the firewall reinforcement plate for a manual brake 67-70 b body! Can anybody lead me to a source or have one laying around? Ebay is bare!
Re: Master cylindercylinder mounting [Re: HotRodRailroader] #2551613
09/18/18 06:39 PM
09/18/18 06:39 PM
Supercuda Offline
Supercuda  Offline
Don't be the exception.
Re: Master cylinder mounting [Re: HotRodRailroader] #2551626
09/18/18 07:06 PM
09/18/18 07:06 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Here is the correct backing plate for 66-70 B-body.
Power has a round hole and manual has a diamond shaped hole.
I might have one. Which did you need? Manual, right?
The ones shown from Dr Diff don't fit your car. Those are for 70-4 E and 71-4 B.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, .
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Master cylinder mounting [Re: moparmarks] #2551807
09/19/18 03:49 AM
09/19/18 03:49 AM
Loves Park, IL
H
H
Loves Park, IL
I need a manual with the diamond shape! Let me know if ya got one.
Re: Master cylinder mounting [Re: HotRodRailroader] #2553049
09/21/18 09:23 PM
09/21/18 09:23 PM
moparmarks Offline
moparmarks  Offline
Sorry I don't have one right now. Thought I did but must have sold all of them already.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Master cylinder mounting [Re: moparmarks] #2553340
09/22/18 07:42 PM
09/22/18 07:42 PM
John_Kunkel Online content
John_Kunkel  Online Content
Part number for the plate is 2534271, here's one on E-bay:
https://www.ebay.com/i/142933226833
