Re: Existing firewall hole for wires, E-body
[Re: BDW]
#2487689
04/25/18 10:19 AM
04/25/18 10:19 AM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
On my 69 road runner, I drilled out the hole where the air grabber cable went. I ran the MSD box wires through a grommet on that hole and mounted box under the dash. There are two dimples on the fire wall just below the cowl panel seam on the passenger side on e-bodies (at least 70 and 71). You could drill out one of those holes with a step drill. On the inside of the car, it should come out just above the heater box. Unless you are already running a shaker then one of the dimples will be already drilled and used for shaker cable.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
