Re: White vinyl interior: best product, method for cleaning?
[Re: A12]
#2487181
04/24/18 11:21 AM
04/24/18 11:21 AM
Posts: 18,157 Mass
DAYCLONA
Mass
If you want to really strip the crap/dirt/aged look from white interior/exterior vinyl, I use 3M general purpose adhesive remover
Word of caution, once you start you have to finish as it really whitens the surface, use ONLY CLEAN WHITE RAGS, make sure you only wipe the vinyl surface,do a small area at a time, change out for a fresh rag as often as possible, don't saturate the area, don't stay in one area too long, give the cleaner time to evaporate and the vinyl time to recover, touch noting else when cleaning as you might smear that color into the white grain, keep it away from painted/dyed surfaces...
All the other "whitening" products pale in comparison
Mike
[Re: A12]
#2487232
04/24/18 01:03 PM
04/24/18 01:03 PM
Silver70
Rust Belt, SW PA
We used to use spray 9 to clean vinyl seats, door panels etc. Pretty much spray and wipe right off with little effort. Doesn't hurt anything if it stays on longer.
[Re: topside]
#2487291
04/24/18 02:18 PM
04/24/18 02:18 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I wonder if Simple Green would work well, I don't recall trying that. Simple Green is overrated, dish soap is a better product than SG
[Re: DAYCLONA]
#2487336
04/24/18 03:30 PM
04/24/18 03:30 PM
Posts: 3,378 KY USA
mopargem
KY USA
I found out Crown available at Walmart is a very good cleaner and safe
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: mopargem]
#2487348
04/24/18 04:07 PM
04/24/18 04:07 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
I tried several different cleaners on my convertible's white top over time and never had much success. Last year I had some work being done on it by a local Mopar shop, and he noticed the dirty top and asked if I wanted him to clean it for me. I said if it wouldn't take much time and run up my bill much more, go ahead. When I got the car back, the top looked like new! He said he used Westley's Bleach white, and a lot of water to rinse it off. Then after he was finished, he used a vinyl preservative like Mothers. I assume it would work equally well on interiors, though it would be best to remove the seats and do them out on the driveway or patio rather than while in the car.
[Re: Silver70]
#2487416
04/24/18 06:28 PM
04/24/18 06:28 PM
Posts: 2,915 Calgary, Alberta Canada
a12rag
We used to use spray 9 to clean vinyl seats, door panels etc. Pretty much spray and wipe right off with little effort. Doesn't hurt anything if it stays on longer. Have also used Spray 9 with good success too ! . . .
[Re: DAYCLONA]
#2487803
04/25/18 02:53 PM
04/25/18 02:53 PM
Posts: 21,498 N.E. OHIO, USA
A12
N.E. OHIO, USA
Thanks Mike I'll cautiously give that a try and funny thing the other day in the auto parts I looked at a can of that exact 3M product and said that might work.....naw, no way Thanks everyone too, for the replies, more replies and experiences are appreciated. Mike
[Re: rallye73]
#2488169
04/26/18 11:14 AM
04/26/18 11:14 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I've used hand cleaner and fairly soft scrub brush with good results. I figured if it's safe for your hands then it should be safe for the seats. Someone recommended using GOOP brand hand cleaner on white interior cleaning, I haven't had the chance to try it though?
[Re: A12]
#2488498
04/26/18 11:48 PM
04/26/18 11:48 PM
Posts: 356 Greenwood Lake, NY
fuelishnsilly
Greenwood Lake, NY
My friend had good luck with Meguiar's #39 Heavy Duty Vinyl cleaner followed up by the #40 Vinyl and Rubber Cleaner / conditioner
inherited a 69 roadrunner from my grand pop.
