motorhome 727
#2486678
04/23/18 01:57 AM
04/23/18 01:57 AM
Posts: 954 garnett kansas
rhad
garnett kansas
i have a 727 out of a 77 or so motor home,it had a 440 in front of it and a Dana 70 behind it,it has a HUGE bolt on yoke on the back of the trans and is a short output shaft,so.....is the shaft diameter and spline count the same as a regular 727 ,or is this dude a creature all of its own?,no plans to use,just wanting info in case
Re: motorhome 727
[Re: rhad]
#2486701
04/23/18 03:45 AM
04/23/18 03:45 AM
Posts: 43,007 Bend,OR USA
There are two versions of the motor home 727, Class A chassis that have the emergency brake on the tail shafts and the class B and c that don't have it there. It sounds like you have one out of a one ton class B or C van chassis To answer your question on both versions they are for motor home applications only I am going to use one of those cores to take parts out them to convert the front of a pre 1967 car tranny to the later front pump and input shafts so I can use the 1967 and later torque converters, the front half share parts with the rest of the 727 of the same years Not so on the back half
Re: motorhome 727
[Re: scratchnfotraction]
#2487089
04/24/18 01:49 AM
04/24/18 01:49 AM
rhad
garnett kansas
thanks guys,it came out of a class a and does not have the e brake on it,dont remember the exact year but it had the dash shifter,not a lot of miles on it but has set for decades!
Re: motorhome 727
[Re: rhad]
#2488988
04/28/18 10:58 AM
04/28/18 10:58 AM
Posts: 11,892 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The tranny can be used in our cars if the output shaft and tail housing are changed. I use that tranny in my builds because it is usually cheap and if Mopar thought that the internal changes were tougher then who am I to argue.
The output shaft from any 727 BB or SB will go into the pinion set, but there are 2 different spline pitches to watch for and mis-matching them will shorten their life expectancy.
'75 and back use a 45* pitch while '76 and up uses a 37.5* pitch. The later shaft has an extra groove in it to identify it.
Master, again and still
Re: motorhome 727
[Re: DaveRS23]
#2489096
04/28/18 03:29 PM
04/28/18 03:29 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Actually there are three different spline angles, it was changed again in '94 to 30°.
