Clutch Fan in Big Block Dart
#2486573
04/22/18 10:14 PM
04/22/18 10:14 PM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
At this point I'm guessing Ma Mopar never offered a clutch fan in a bigblock Dart. Tried installing one, no way no how.
Abe Lincoln
Re: Clutch Fan in Big Block Dart
[Re: TooMany62s]
#2486734
04/23/18 09:52 AM
04/23/18 09:52 AM
Posts: 43,517 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Yes there were clutch fans for big block A-Body's, no you cannot find a correct one. The normal non clutch fan has a .70 spacer which is equally hard to find.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2486802
04/23/18 01:18 PM
04/23/18 01:18 PM
dart4forte
Mesa, Arizona
Yes there were clutch fans for big block A-Body's, no you cannot find a correct one. The normal non clutch fan has a .70 spacer which is equally hard to find. Thanks. Okay, have to ask, anyone with a bigblock Abody running a Hayden clutch fan? Moving the rad is not an option.
Abe Lincoln
[Re: Rhinodart]
#2486849
04/23/18 03:09 PM
04/23/18 03:09 PM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
Yes there were clutch fans for big block A-Body's, no you cannot find a correct one. The normal non clutch fan has a .70 spacer which is equally hard to find. I was on a hunt last year for this spacer as I thought I got one years ago, but could not locate in my stash. After looking at what seemed like a few hundred at Carlisle, finally found.
[Re: dart4forte]
#2486911
04/23/18 05:37 PM
04/23/18 05:37 PM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
I used the mopar performance clutch with the original fan in 69 M code Cuda with factory spacer
edit Sorry got mixed up with my small block the M code was solid mounted
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: topside]
#2486924
04/23/18 06:21 PM
04/23/18 06:21 PM
Posts: 1,788 Greer, SC
TooMany62s
Greer, SC
Isn't there a short one for a Jaguar application? The "direct-drive" fan on mine is actually too efficient at speed; thinking about getting another with fewer blades (car is not a resto), or a clutch style. The Jaguar part will work but the 2947 is a better option. Jags had a plastic fan. The 2947 is designed to replace the original Mopar part. I think the 2947 is designed specifically for the '62 - '65 applications that had very little water pump to radiator clearance.
[Re: TooMany62s]
#2486957
04/23/18 08:17 PM
04/23/18 08:17 PM
Posts: 4,666 Wichita
GY3
Wichita
Isn't there a short one for a Jaguar application? The "direct-drive" fan on mine is actually too efficient at speed; thinking about getting another with fewer blades (car is not a resto), or a clutch style. The Jaguar part will work but the 2947 is a better option. Jags had a plastic fan. The 2947 is designed to replace the original Mopar part. I think the 2947 is designed specifically for the '62 - '65 applications that had very little water pump to radiator clearance. The Jag part is what I run on my '63. Works perfect, but I still had to move the tank saddles rearward on my stock radiator 1/2".
