Dome/ Dish volume known for 77 400 HP piston #2486461
04/22/18 05:07 PM
04/22/18 05:07 PM
Indiana
68_661charger Offline OP
Indiana
Playing practicing figuring compression ratio on a known stock 77 400 engine for fun to see how it works. I have all measurements taken except dome/dish volume on the piston. Is there a factory trusted figure I can use in Ccs or do I have to figure it out on my own? Thanks.
Re: Dome/ Dish volume known for 77 400 HP piston [Re: 68_661charger] #2486471
04/22/18 05:41 PM
04/22/18 05:41 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
pretty sure they are just flat tops; no dome or dish. all you need is pin height.
Re: Dome/ Dish volume known for 77 400 HP piston [Re: lewtot184] #2486476
04/22/18 06:06 PM
04/22/18 06:06 PM
John_Kunkel Offline
John_Kunkel  Offline
iagree Flat tops.
Re: Dome/ Dish volume known for 77 400 HP piston [Re: 68_661charger] #2486500
04/22/18 06:59 PM
04/22/18 06:59 PM
Indiana
Indiana
Oh ok. I guess I never entertained zero as the number but that makes sense. Thanks.
Re: Dome/ Dish volume known for 77 400 HP piston [Re: 68_661charger] #2486537
04/22/18 08:38 PM
04/22/18 08:38 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Just for kicks and giggles, NHRA blueprint specs for a 74/75 400-4 Are min head volume of 83.1 67cc and max deck height of - .075.
Although not currant it will give you an idea of stock specs at on time.
Have a great day
Iowan
"obsolete is neat"
Re: Dome/ Dish volume known for 77 400 HP piston [Re: Iowan] #2486889
04/23/18 04:49 PM
04/23/18 04:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
NHRA specs and what actually rolled off the assembly line of the Chrysler corporation are not even remotely the same.
Re: Dome/ Dish volume known for 77 400 HP piston [Re: 68_661charger] #2486943
04/23/18 07:17 PM
04/23/18 07:17 PM
John_Kunkel Offline
John_Kunkel  Offline
From my own measurements of an untouched 400:
Pin height= 1.812"
Deck height= .122"
Head= 90 cc
Gasket= .022"
CR= 7.52-1
