Rear brake line bracket. #2486089
04/21/18 03:03 PM
04/21/18 03:03 PM
UPPER MICHIGAN, MARQUETTE COUN...
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
After pulling this 69 Charger apart 12 years ago I am finally staring the reassembly. I have hundreds of pictures but for some reason none of this area. I just need to see which way the bracket went and how the steel line went to the left frame rail. Any pics would be great. Thanks.
Re: Rear brake line bracket. [Re: NITROUSN] #2486558
04/22/18 09:42 PM
04/22/18 09:42 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Which brake line - fluid or e-brake?
Which bracket - the one under the driver's floor or the one on the rear frame rail ??
Frame rail e-brake bracket: the steel line from each side on the read end housing clip into the bracket and attach to a two-into-one bracket that the e-brake cable attaches to.
Re: Rear brake line bracket. [Re: Stanton] #2486590
04/22/18 10:47 PM
04/22/18 10:47 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
It is the bracket that hangs from the body where the rear axle flex hose attaches with the steel line. I would like to see a picture which would clarify its position as well as the steel line routing along the rear floor to the left frame rail.
Re: Rear brake line bracket. [Re: NITROUSN] #2486593
04/22/18 10:54 PM
04/22/18 10:54 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Try this. This is a brake line and how it is routed. There is a clip that holds in on the outside face of the frame rail.
Let's not try to make this any harder than it has to be. LOL
Re: Rear brake line bracket. [Re: NANKET] #2486603
04/22/18 11:12 PM
04/22/18 11:12 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
That make more sense. I am attaching it to a bracket that is welded to the body floor and has a weld nut. I also see your e-brake cable and am wondering if that attaches to the body bracket that I thought the line bracket went to. Do you by some chance have a pic of the right e-brake cable routing?
Re: Rear brake line bracket. [Re: NANKET] #2486615
04/22/18 11:33 PM
04/22/18 11:33 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Here is a 10 year old photo when I welded the Hemi pinion snubber plate in. I circled in red where I thought it should go. After looking at your photo I see where mine needs to go circled in green. Thanks for the help.
Re: Rear brake line bracket. [Re: NITROUSN] #2487064
04/24/18 12:19 AM
04/24/18 12:19 AM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Thanks for the help. Went out in the shop and made sense of things. Now on to the next job.
Re: Rear brake line bracket. [Re: NITROUSN] #2487106
04/24/18 02:53 AM
04/24/18 02:53 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes the right side brake cable bolts to that bracket circled in red.
