v belt squeals
#2485660
04/20/18 04:19 PM
04/20/18 04:19 PM
Posts: 12 arizona usa
oldschool
arizona usa
I don't think i have ever had this problem.3000rpm and above,belt that runs water pump, p/s pump squeals.I have sanded pulleys changed w/p,tried different fan combos nothing helps.Its a new set up,squealed from day one.383 .040 over, pulleys off a 440 m/h.pulleys align with straight edge and don't wobble.please help,pulling what hair i have left out.thanks ,BILL
Re: v belt squeals
[Re: oldschool]
#2485664
04/20/18 04:23 PM
04/20/18 04:23 PM
Posts: 1,129 Home of the Bluegrass
MoparJunkie
Inquiring minds want to know.... I currently have the same issue kicking my azz!
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: v belt squeals
[Re: oldschool]
#2485832
04/20/18 10:45 PM
04/20/18 10:45 PM
I always thought that if a pulley or belt was worn enough that the belt touched the bottom of the groove that that WAS the problem (but I may be all wrong there). if your pulleys are aligned) & belt tight which I'm sure it is by now) then it about has to be wrong/worn belt (likely) or worn pulley (way less likely). Holler how it goes.
Re: v belt squeals
[Re: oldschool]
#2486067
04/21/18 02:11 PM
04/21/18 02:11 PM
Posts: 1,696 central il.
second 70
central il.
Old change the belts to dayco top cog as in earlier post. My hemi would throw and break belts at rpms until I switched. No problems in 8 years. I was able to get a deal on a bunch of different sized unused belts from a nascar team to see what length fit best. I ended up with the 15470 for alternator and 15440 for power steering.
The first 2 numbers mean it’s 15mm or 7/16 wide the last 3 are length. The last number can be a 5 for half inch. So if yours fix good just measure them in inches and add that number to the 15.
I will bet your problem will be over with the new belts.
Re: v belt squeals
[Re: second 70]
#2486278
04/22/18 01:47 AM
04/22/18 01:47 AM
Posts: 68 southeast NE
lemondana
southeast NE
The first 3 numbers mean it’s 7/16 wide the last two are length so if yours fix good just measure them in inches and add that number to the 154.
I will bet your problem will be over with the new belts. The first 2 numbers are the width- 15 mm, the last 3 numbers are the length-47 and 44 inches long. All of our older Mopars were designed to use the 13 mm wide belts, pretty much unavailable today. 95 % of the Mopars use the 15 series belt which ride up out of the pulley a little amount.
Re: v belt squeals
[Re: lemondana]
#2486376
04/22/18 12:55 PM
04/22/18 12:55 PM
second 70
central il.
I will bet your problem will be over with the new belts. The first 2 numbers are the width- 15 mm, the last 3 numbers are the length-47 and 44 inches long. All of our older Mopars were designed to use the 13 mm wide belts, pretty much unavailable today. 95 % of the Mopars use the 15 series belt which ride up out of the pulley a little amount. Thanks lemondana I stand corrected. I was going off of memory which wasn't working correctly. But I do know theses belts work.
