Re: 69 Charger Fuel Pump/Line Question
[Re: 70runner]
#2487608
04/25/18 01:12 AM
04/25/18 01:12 AM
Posts: 18,406 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
69 Charger 440, AVS carb. Carter website shows M4434 as correct fuel pump, with a 1/8-27 female inverted flare (output) and 5/16 hose barb input. Confirmed with their tech rep. Right Stuff website shows the RPC7001 pump to carb kit, 2 lines, for same application. Their tech rep said both lines have 1/2-20 male threads.
Is an adapter, 1/8-27 male to 1/2-20 female, commonly used for this setup, or is there an alternative fuel pump for the 440 with a 1/2-20 output thread? If your pump has the 1/8 27 npt ports you need to have the brass fittings to go 1/8 27 male to 5/16 inverted flare which is 1/2 20 threads per inch. The line kit you are looking at will work as long as you have the correct pump and carb size fittings.
