Textured paint on 1971 B Body dash?
#2476898
04/03/18 05:45 PM
04/03/18 05:45 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
Hi all, While my dash is out, I'm repairing a few holes that a prior owner put in for switches that aren't used any more: https://photos.app.goo.gl/Bctad0CCPzSPgzq02The (black) paint on the dash feels like it has a texture to it. Is there a specific paint I should use for this, that will match this texture? Thanks for any suggestions. Roger
Re: Textured paint on 1971 B Body dash?
[Re: Fab64]
#2476921
04/03/18 06:24 PM
04/03/18 06:24 PM
Posts: 892 MA
steve70
MA
You can buy the paint from Instrument Specialties in RI http://www.instrument-specialties.com/Here a picture of my 71 dash they restored for me.
1970 Challenger T/A 4 speed
[Re: Fab64]
#2482578
04/14/18 01:50 PM
04/14/18 01:50 PM
Posts: 3,691 MO
cdp
MO
I have had and still have a few 71 -b-bodies (GTX and RR) None used the "suede" finish that I've experienced so far. Service manual says low gloss. All the ones I had were St. Louis built.
TCP Global Color Library is a great website with factory color sheets you can view for interior and exterior colors.
http://images.tcpglobal.com/chips/1971-Plymouth-pg02.jpg?linkingParam=%7B%22_ga%22%3A%22GA1.2.1558827073.1523720885%22%7D&_ga=2.248051343.925835483.1523720885-1558827073.1523720885
I have some suede paint from them for my 69 RR "(AL-TCP9324(A)" is whats on the can. It was an exact match. On the Rustoleum, it is very close also, but I found you need a good temp to spray at as it tiger striped allot from a basic can nozzle.
[Re: Stanton]
#2482582
04/14/18 02:04 PM
04/14/18 02:04 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Powdercoat is not an option if your repairs involve any fillers. If you use "LAB METAL" filler, you can powdercoat
[Re: Fab64]
#2482655
04/14/18 05:42 PM
04/14/18 05:42 PM
Posts: 8,859 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
you need a good temp to spray at as it tiger striped allot from a basic can nozzle This is very true - especially on the large top surface. I sanded and resprayed mine at least 3 times. I finally got it decent. In hindsight I'd shoot it with a satin first then fog on the texture which I think would eliminate the tiger striping.
[Re: cdp]
#2551654
09/18/18 08:29 PM
09/18/18 08:29 PM
Fab64
So Cal, USA
Ok, five months later and I'm finally getting ready to paint after making my repairs. On closer examination of my dash, I've noticed that the textured surface has not been applied very consistently. For example, the ash tray is totally textured, while the glove box door is not at all (see attached pic). The dash itself is kind of a mixture, with some areas lightly textured, and some not much or at all. Is this common? Perhaps it was done rather haphazardly, in the same way the blacked-out area behind the grill was sloppily shot? Again, not a restoration, so it's not that important - just want it to look decent and somewhat correct.
Before shooting the textured, I'm planning to base coat the dash with a satin or low-gloss black. I've compared the existing satin finish on the glove box door with Eastwood's Underhood Black, and the glove box door is less glossy. It seems to fall somewhere between the Eastwood Underhood black and plain flat black. Any suggestions for a lower-gloss black than Eastwood's Underhood black?
Thanks for all help!
[Re: Fab64]
#2551916
09/19/18 01:30 PM
09/19/18 01:30 PM
Posts: 7,363 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
My 73 didn't have much if any texture. I used SEM Trim Black on it but on the final coat, I sprayed it from a farther distance which mimicked the original finish perfectly. On my 68 Dart, it was definitely suede and had a lot more texture. I also used Rustoleum "textured" black. I sprayed a clear coat over top of the texture to make it more durable. You could also spray a satin black over the top of the texture to dull it down a little so the texture isn't so pronounced. Here's what the Rustoleum looks like on my steering column.
