Best way to restore a cross ram magnesium intake
#2470456
03/22/18 04:05 PM
03/22/18 04:05 PM
Posts: 3,391 cheshire, ct
davesmopars
cheshire, ct
I will try here first, not really sure where to post this. Best way to restore a cross ram magnesium intake Thanks for any help
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
Re: Best way to restore a cross ram magnesium intake
[Re: Stanton]
#2470570
03/22/18 07:01 PM
03/22/18 07:01 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
All that i ever did with mine was to put it in the bead cleaning cabinet, and went and did it's thing on it. Haven't got a clue as to the type of grit that was in the cabinet at that time. Whoever had the cabinet, where i worked at the time.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: davesmopars]
#2470661
03/22/18 08:38 PM
03/22/18 08:38 PM
Posts: 43,096 Bend,OR USA
Those manifolds are corroding all the time, even after having them cleaned up, unless you have them Dow Coated to prevent further corrosion I installed one last year on a early 1966 street Hemi motor in a 1963 Dodge Polara 440 hardtop for a friend and his Son, it was brand new and part of it was corroded black and part was dark gun metal grey from corrosion I had a old 426 Hemi Cragar magnesium blower manifold cleaned and Dow coated by Mert Littlefield blower company a long time ago, it looks exactly the same now as it did when we had it done is what my customer is saying I had a old set of Motor Wheel Magnesium rear rims, what a pain to keep up
[Re: Cab_Burge]
#2470680
03/22/18 09:13 PM
03/22/18 09:13 PM
Posts: 1,817 South Bend
John Brown
South Bend
Gibbs oil, according to the street rod freaks on the H.A.M.B. Don't believe much they have to say, but I have friends that use it and swear by it.
[Re: davesmopars]
#2470796
03/23/18 01:50 AM
03/23/18 01:50 AM
davesmopars
cheshire, ct
Restoring a BO29 Car. Its an original 68 BO29 intake, its nasty looking. I did not know it I could bead blast it. If so what grit? and if I can, what do I do to keep nice? thanks
[Re: John Brown]
#2470817
03/23/18 03:22 AM
03/23/18 03:22 AM
Posts: 275 brisbane,australia
coletrickle
brisbane,australia
Gibbs oil, according to the street rod freaks on the H.A.M.B. Don't believe much they have to say, but I have friends that use it and swear by it. GIBBS BRAND LUBRICANT ,Its the best for magnesium,it seems like snake oil when you speak of it.But when it comes to corrosion its the best.NASA do not do an electrical connection with out GIBBS,.It is a must have in the workshop/home.if its 45 bucks here in oz it should be 20 bucks US ,Give it a try.😆
[Re: davesmopars]
#2470818
03/23/18 03:31 AM
03/23/18 03:31 AM
coletrickle
brisbane,australia
Restoring a BO29 Car. Its an original 68 BO29 intake, its nasty looking. I did not know it I could bead blast it. If so what grit? and if I can, what do I do to keep nice? thanks Once blasted its not the correct finish,I aquired an old supercharged nitro honda cb350 as last raced in 1976,it had a lot of heavyish corrosion etc just been spraying with Gibbs every couple of months for the last year,corrosions all gone rust spots on chrome gone paint is more vibrant and all cracks in rubbers gone and its offically still as found nothing more than some really gentle rubbing on some of the crustiest spots.Pretty much spent $80 and done [censored] all and its finished .
[Re: coletrickle]
#2470832
03/23/18 05:18 AM
03/23/18 05:18 AM
PasiR
[Re: davesmopars]
#2470879
03/23/18 11:15 AM
03/23/18 11:15 AM
Posts: 2,629 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I don't blast if I can keep from it. If you want the natural finish you can remove the paint with stripper (might take many applications). When you have the paint off, spray it with WD-40, it will soak it in. Be sure to spray inside the runners and underneath. Might need to do it once a week for awhile until it stabilizes then it will last a long time. Decades.
2011 Drag Pak Challenger
[Re: rickseeman]
#2470975
03/23/18 03:00 PM
03/23/18 03:00 PM
dogdays
X 10 on no blasting. It changes the surface forever, or at least until you can have the factory finish redone, which may be never. Maybe baking soda will clean without changing the surface, but glass beading makes it furry. For a slightly different look, I glass beaded all the aluminum on one engine and then shot it with high temperature clear. Now it's a shiny gray color, but that's what I was after. Gibbs Lubricant is entirely different from Joe Gibbs Driven motor oil. Here's a link: http://www.gibbsbrandlubricant.com/shop.htmR. Let's not forget Boeshield T-9. https://boeshield.com/products/
[Re: dthemi]
#2472708
03/27/18 12:41 PM
03/27/18 12:41 PM
davesmopars
cheshire, ct
Mag parts look amazing in DOW7 coating. Have you used it or know somebody that does this? thanks
[Re: davesmopars]
#2472743
03/27/18 01:49 PM
03/27/18 01:49 PM
Mag parts look amazing in DOW7 coating. Have you used it or know somebody that does this? thanks Try contacting Littefield blowers,714-992-9292, for that
[Re: davesmopars]
#2483768
04/16/18 06:43 PM
04/16/18 06:43 PM
davesmopars
cheshire, ct
can I have the machine shop hot tank the intake?
[Re: davesmopars]
#2483803
04/16/18 07:51 PM
04/16/18 07:51 PM
Posts: 8,853 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
can I have the machine shop hot take the intake? Not if you ever want to see it again !!
[Re: Stanton]
#2483898
04/16/18 10:15 PM
04/16/18 10:15 PM
davesmopars
cheshire, ct
Thanks, thats what I thought.
[Re: Cab_Burge]
#2483903
04/16/18 10:21 PM
04/16/18 10:21 PM
davesmopars
cheshire, ct
So I called these guys, talked about the process and then I asked him how to take the paint off and he's said to sand blast it. Everyone says not to. He said 300.00 to polish it and 250.00 to have it coated.
