Re: What went wrong?
[Re: Shatar4]
#2548511
09/10/18 07:24 PM
09/10/18 07:24 PM
Posts: 4,664 Wichita
GY3
Wichita
Jeez, what a stupid mistake! I've seen combos that don't run like they should and people always blame the cam. I always ask if they degreed it and 9 times out of 10 they say, "I made sure and lined up the dots!".
[Re: GY3]
#2548515
09/10/18 08:03 PM
09/10/18 08:03 PM
Posts: 20,154 PA.
pittsburghracer
For you guys that struggle with degreeing in cams buy yourself this tool. It sure make the job a lot easier. https://www.summitracing.com/oh/parts/cca-4926
[Re: RATTRAP]
#2548518
09/10/18 08:35 PM
09/10/18 08:35 PM
Posts: 1,038 Howell, Mi
Shatar4
Howell, Mi
Anyone know of one that is around the Detriot area? Called Jakes this morning and they were 3-4 weeks out.
You an try Full Throttle racing In Fraser,MI they have a chassis dyno. Got it covered! Jake was awesome and fit me in sooner! đź‘Ť
[Re: Shatar4]
#2548572
09/10/18 11:19 PM
09/10/18 11:19 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I got him coming in Thursday.
JAKES AUTOMOTIVE
[Re: Shatar4]
#2549718
09/13/18 06:49 PM
09/13/18 06:49 PM
Shatar4
Howell, Mi
Just got home from the dyno at Jakes. First I have to say Gary at Jakes is awesome fortaking care of me. So now the numbers. For a Stroker motor that has only parts from out of the box I think it’s pretty good adding in the power train lose. 414 hp and 429 torque.
[Re: Shatar4]
#2549754
09/13/18 09:05 PM
09/13/18 09:05 PM
Superfreak
Superfreak
[Re: davenc]
#2549809
09/13/18 11:58 PM
09/13/18 11:58 PM
Posts: 566 Texas
RustyM
Texas
Agree with Dave. Was that with an air cleaner on it?
I cannot remember if this is a carb or efi? Wondering if valve train is getting unstable at 5k and above as well. Certainly seems really lean to me.
[Re: pittsburghracer]
#2549853
09/14/18 04:25 AM
09/14/18 04:25 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
That tool is nice for checking cam centerline. I have seen it mis-used trying to set/measure opening and closing events or duration. The results will be slightly off because the follower diameter of the tool is smaller (0.841" is what mine measured) than a real MOPAR lifter (0.904".) I don't know the radius used for the rounded follower used for roller cams? If I want to measure duration or opening and closing events, I use the actual lifter the engine will be using as the roller cam lifters may have different diameter rollers.
[Re: Shatar4]
#2549917
09/14/18 11:53 AM
09/14/18 11:53 AM
Well after i took the motor back out and gave it to the engine builder, he found that he acidently put the timing off by one tooth. I took the heads off and the valves were kissing the pistons leaving a half moon mark on them. So, two things that I would consider pretty much “mandatory” for a build like this obviously didn’t get done. Cam didn’t get degreed, and valve to piston clearance not verified. I dynoed a very mild 505 last fall that was similar, but milder. Stage 1 rpm heads, .483 lift hyd cam, original Torker, 850vs carb, 1-7/8” headers. I told him it would make about 600ft/lbs and 500hp. It made 628tq/515hp. With an RPM intake and the OP’s cam I would have been looking for another 40-50hp. Back in about 1990, on a 500hp 440 I tested an original Torker against a Torker II. The Torker II had noticeably better top end power than the original Torker, which resulted in a peak gain of about 15hp, but at the top of the run it was more like a 30hp difference. The original Torker had better bottom end and made about 15ft/lbs more peak tq.
[Re: RustyM]
#2550046
09/14/18 06:01 PM
09/14/18 06:01 PM
Shatar4
Howell, Mi
The air cleaner was not on it. It is a 850 carb.
[Re: fast68plymouth]
#2550049
09/14/18 06:08 PM
09/14/18 06:08 PM
Shatar4
Howell, Mi
Well after i took the motor back out and gave it to the engine builder, he found that he acidently put the timing off by one tooth. I took the heads off and the valves were kissing the pistons leaving a half moon mark on them. So, two things that I would consider pretty much “mandatory” for a build like this obviously didn’t get done. Cam didn’t get degreed, and valve to piston clearance not verified. I dynoed a very mild 505 last fall that was similar, but milder. Stage 1 rpm heads, .483 lift hyd cam, original Torker, 850vs carb, 1-7/8” headers. I told him it would make about 600ft/lbs and 500hp. It made 628tq/515hp. With an RPM intake and the OP’s cam I would have been looking for another 40-50hp. Back in about 1990, on a 500hp 440 I tested an original Torker against a Torker II. The Torker II had noticeably better top end power than the original Torker, which resulted in a peak gain of about 15hp, but at the top of the run it was more like a 30hp difference. The original Torker had better bottom end and made about 15ft/lbs more peak tq. So do you think if I change the intake to a Edelbrock RPM I would gain some?
[Re: Shatar4]
#2550057
09/14/18 06:35 PM
09/14/18 06:35 PM
“Some”? Sure...... but mostly in the lower part of the curve is what I’d expect.
Peak hp would likely be within 10.
Way more work involved, but I’d expect better results out of some head porting instead.
[Re: Shatar4]
#2550142
09/14/18 11:34 PM
09/14/18 11:34 PM
Posts: 598 NC, USA
davenc
NC, USA
If the dyno operator has confidence in the AFR values posted in that dyno chart, you should be able to pick up some decent power jetting up on the carb. It looks pretty lean on those runs. The timing might also be more optimized once the AFR was richer.
[Re: davenc]
#2550529
09/16/18 03:40 AM
09/16/18 03:40 AM
Shatar4
Howell, Mi
If the dyno operator has confidence in the AFR values posted in that dyno chart, you should be able to pick up some decent power jetting up on the carb. It looks pretty lean on those runs. The timing might also be more optimized once the AFR was richer. The jets at 80 primary 88 secondary.
