Misfire (Hot idle compensator AVS) #2468311
03/18/18 09:25 PM
03/18/18 09:25 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
Anyone ever experience this? The Hot idle compensator opening up and causing a misfire at about 4500 rpm under load?
Re: Misfire (Hot idle compensator AVS) [Re: SSDart] #2468331
03/18/18 10:11 PM
03/18/18 10:11 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
many years ago i had customers 69 GTX do that,i end up plugging the hole with a lead ball. every thing work fine after that.
Re: Misfire (Hot idle compensator AVS) [Re: dodger mope] #2468353
03/18/18 10:51 PM
03/18/18 10:51 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
That's interesting. We had it happen on the dyno this weekend. It happened sporadically. I noticed after it happened the idle went way lean too.
I'm kinda hoping that's the issue... seems odd it could happen at that rpm WOT.....
Re: Misfire (Hot idle compensator AVS) [Re: SSDart] #2468412
03/19/18 12:37 AM
03/19/18 12:37 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
They work by temp and should only open on very hot eng temps as they just let more air to the eng when it gets real hot. Its a bi-metal that opens when very hot as it sounds like its not working right. As long as your eng does not run to hot you really should get by without it. Ron
