Big Block flex plate
#2466159
03/14/18 12:59 AM
03/14/18 12:59 AM
Posts: 1,090 Saskatchewan, Canada
barracudabob
I want to replace the flex plate on my '76 440. This is an externally balanced engine, and has a weight on the converter. Looking at B&M's website, they show one for an externally balanced big block, PN 10237. It has a scallop on one side. When using this flex plate, do I need the weight on the converter as well, or can any converter without the weight be used? Thanks in advance, Bob
Re: Big Block flex plate
[Re: Dave Hall]
#2466268
03/14/18 10:59 AM
03/14/18 10:59 AM
Posts: 4,664 Wichita
GY3
Wichita
I used the scalloped B&M on my last cast crank 440 with a neutral balance converter. Worked perfectly.
[Re: Kern Dog]
#2466419
03/14/18 03:37 PM
03/14/18 03:37 PM
an8sec70cuda
The scallop is there to compensate for the engine balance factor. In other words, the B&M flexplate allows you to use any neutral balance converter. Grind the welds to remove the weights from the converter.
