Re: Leak proof valve cover gaskets
[Re: fastmark]
#2465003
03/11/18 11:31 PM
03/11/18 11:31 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
YES , silicone the rubbers to the covers, let them dry and put them on and take them off for years.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: fastmark]
#2465007
03/11/18 11:40 PM
03/11/18 11:40 PM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
Have never had a leak w/superperformance or moroso blue. I have had the moroso blues on my wagon for 5 yrs. In that time the gaskets have been removed w/the VC several times for routine lash checks.
Ok
[Re: Thumperdart]
#2465125
03/12/18 10:56 AM
03/12/18 10:56 AM
Posts: 6,387 Abilene, Texas
fastmark
Abilene, Texas
You are officially the biggest ass hat on Moparts........... Who are we referring too as the ass hat? We only have the one leak on this car, the back of the valve covers. Thanks for the ideas guys. I’ll order one of the suggested gaskets and see how it works.
[Re: A39Coronet]
#2465175
03/12/18 12:55 PM
03/12/18 12:55 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Blue Moroso Perm-align gaskets. Rubber with steel inner skeleton. Best I've ever used, no leaks, reuseable. I'll never run anything else. X2
[Re: fastmark]
#2465217
03/12/18 02:37 PM
03/12/18 02:37 PM
Thumperdart
State of confusion
You are officially the biggest ass hat on Moparts........... Who are we referring too as the ass hat? We only have the one leak on this car, the back of the valve covers. Thanks for the ideas guys. I’ll order one of the suggested gaskets and see how it works. Not you bro Mr Andy F...........
[Re: fastmark]
#2466285
03/14/18 11:34 AM
03/14/18 11:34 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I like these from Fel-Pro. My intake doesn't sit flush with the valve cover rail and these are thick enough to deal with that interference. I have even had good luck using them over and over after valve lash checking etc. https://www.summitracing.com/parts/fel-1...ASABEgKGbPD_BwEI would imagine they make a similar one for a big block as well.
68 Barracuda Formula S 340
[Re: fastmark]
#2466450
03/14/18 04:11 PM
03/14/18 04:11 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
All -- there is no gasket better than its installation! Regardless of material:
1. Make certain mating surfaces are straight and flat; stamped steel tends to become distorted, so, re-flatten or replace. Cast aluminum tends to remain flatter and is preferred when that option exits.
2. Check the cyl head gasket surface -- some casting flash may exist and needs to be smoothed flat.
3. Clean the threadings -- eliminate friction of dirt (nuts, bolts, studs, etc).
4. Follow proper torque specs -- do NOT over-tighten!
5. Do NOT use RTV silicone on the gaskets as it only acts as a lubricant to allow the gasket top slip out of position! IF nthe gasket has installation tabs that can fit into the cover, that is what holds and positions the gasket to the cover. If no tabs, a quick-drying contact cement can be used (NOT RTV).
6. The gasket does the sealing, not any chemical.
There are hi-temp options of material to resist the extreme heat of the hi-rise exhaust manifolds... see the Fel-Pro catalog.
I worked as an aftermarket engineer with Fel-Pro for nearly 30 years and I know all the stories and issues. Read the directions -- I wrote them.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
