Radiator/Fan Combo #2464415
03/10/18 06:58 PM
03/10/18 06:58 PM
John_Kunkel Offline OP
Due to space constraints I'm limited to 22" radiator size to cool my 360LA. I'm looking at the Champion MC-2374 3-row with fans but am skeptical that the two 10" fans (combined 2100 CFM) will do the job.
Anybody running this combo with a small block and A/C? How's it working for you?
Re: Radiator/Fan Combo [Re: John_Kunkel] #2464417
03/10/18 07:03 PM
03/10/18 07:03 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
I had those fans running on a big block car, they didn't move enough air for my car. I have a/c and an automatic trans, I overheated in my driveway coming home from work one day. I moved up to spal fans, but I haven't run the car in hot weather yet. I can say the spal fans move considerably more air than the champion fans did. Had I known before I would have gotten the shroud and sourced my own fans.
Re: Radiator/Fan Combo [Re: John_Kunkel] #2464431
03/10/18 07:40 PM
03/10/18 07:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That rig sure looks like it blocks a lot of air flow.
Re: Radiator/Fan Combo [Re: stumpy] #2464457
03/10/18 09:00 PM
03/10/18 09:00 PM
IN
ahy Offline
ahy  Offline
IN
Rule of thumb you need 5000 CFM fan capacity. Not enough. Also agree it would block air flow at speed.
The stock style fan/shroud works pretty darn well. That is what I would suggest. Over drive the fan at least a little and I bet it works fine.
Re: Radiator/Fan Combo [Re: John_Kunkel] #2464527
03/11/18 12:15 AM
03/11/18 12:15 AM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
Also one thing to consider is,that I think you will need a 100 amp alt to run them. And the added voltage can fry the wiring at the bluk head connection. Our cars came with 37 amp alts and that's what the wiring is designed for. I could be wrong on this but that's my understanding.
Re: Radiator/Fan Combo [Re: magiccuda] #2464543
03/11/18 01:24 AM
03/11/18 01:24 AM
RapidRobert Offline
RapidRobert  Offline
I would do Nachos' bulkhead parallel bypass & relay the fans right to the alt.
Re: Radiator/Fan Combo [Re: John_Kunkel] #2464715
03/11/18 01:27 PM
03/11/18 01:27 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Not as pretty but many say the Chev HHR fan can't be beat.
Re: Radiator/Fan Combo [Re: Stanton] #2464794
03/11/18 03:56 PM
03/11/18 03:56 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Everything I have read about Champions fans is not good. Their radiators seem OK but the fans just don't seem to do the job. Also as previously mentioned a lot of the core is being blocked and I would suggest louver's or rubber flapper doors twocents
Re: Radiator/Fan Combo [Re: John_Kunkel] #2464817
03/11/18 05:11 PM
03/11/18 05:11 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Most of the aftermarket fans sold are pure garbage.
You'd be a lot better off with a fan like the HHR / 3.8 Taurus / 4-cyl contour single fan on a 22"
If you had a 26", the V6 Contour fan is basically the greatest thing since sliced bread. I don't even need the high speed the fans have.
I'm also running a contour fan, EFI, Aeromotive 340lph fuel pump, and everything else on the car on a 78a 12SI Delco alternator.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Radiator/Fan Combo [Re: John_Kunkel] #2464821
03/11/18 05:20 PM
03/11/18 05:20 PM
P
Porter67 Offline
Porter67  Offline
P
This is a setup ive used on a 1/2 filled small block with 4:88 gears on the street.
Dual HD spal fans with a dual pass cross flow rad and cover that also lets air move.
Ive one fan hooked to a T stat in the intake and the second fan on a toggle.
Ive never had to use the second fan unless I want a rapid cool off before I shut it down.
I got the paperwork on the specs if youd like them.
Re: Radiator/Fan Combo [Re: goldduster318] #2464822
03/11/18 05:21 PM
03/11/18 05:21 PM
"Space constraints" is the key phrase. All of the suggested fans are too thick to fit my installation.
Looking for actual user inputs.
Re: Radiator/Fan Combo [Re: John_Kunkel] #2464828
03/11/18 05:29 PM
03/11/18 05:29 PM
P
Porter67 Offline
Porter67  Offline
P
Sorry I do know those cheap ones arnt worth jack, ve replaced many for others.
Some have mounted things on the front of the core support vs the normal location.
Re: Radiator/Fan Combo [Re: Porter67] #2466043
03/13/18 09:51 PM
03/13/18 09:51 PM
IN
ahy Offline
ahy  Offline
IN
OK... stock style fan won't fit, dual Spal won't fit, Contour/Taurus fan won't fit, HHR fan won't fit. These options all seem to work fine but fit is the issue.
What is the space limitation? A pic would help. Maybe generate some ideas.
Re: Radiator/Fan Combo [Re: John_Kunkel] #2466119
03/13/18 11:45 PM
03/13/18 11:45 PM
Chicago
PurpleBeeper Offline
Chicago
Yeah, I agree with ahy. Can you post a picture and/or tell us what your space constraints are? Two big turbos sticking out the front?
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Radiator/Fan Combo [Re: ahy] #2466533
03/14/18 06:33 PM
03/14/18 06:33 PM
Battery on one side, fuel command on the other, 24" between them; WP hub 3 1/5" from radiator core. Engine mounted low so center of WP is way below core center.
Re: Radiator/Fan Combo [Re: John_Kunkel] #2466642
03/14/18 10:40 PM
03/14/18 10:40 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Hi John wave
Here is the fan I use. Mine is set up as a pusher but you have enough room to set it up as a puller. This unit is a little under 2.75in thick. This is a dual speed fan but I have mine set up to run full tilt whenever the thermostatic switch powers it up. I have a Derale adjustable switch with 30amp relay set to 170* and it will hold that temp all day long...even in 100*F ambient air temps.
Once, a few years back, I was in the staging lanes and forgot to hit the toggle switch that powers the relay and noticed water temp at 220* shock Then I realized the relay hadn't been powered up. Within 60 seconds the temp was back down to 170* thumbs This is a big 572ci Stroker (700+ HP) so it builds some serious heat.
I recommended the same fan to a buddy who runs a Roots blower on his 500in street build. He was having trouble with overheating in the hot Tenessee summer weather. On my recommendation he tried the Rainbow 17" fan setup and it solved all his problems. He was totally impressed.
These are 2 of my experiences and there are others ; 2 other buddies are running them on Pro-Charger BB builds with the same excellent results. Both cars are street/strip B-Bodies that run well into the 9's apimp
http://www.rainbowproductsonline.com/shroud-fan-assembly/cf-item20017-dual-cage.php
Hope this helps...
Ron
Re: Radiator/Fan Combo [Re: goldduster318] #2466900
03/15/18 01:56 PM
03/15/18 01:56 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
How did you wire it? RockAuto pic looks like it has two connections (I assume 1 for each fan) and I didn't see a ground connection. It looks like there might be some logic, given the size of the cooling provisions in and the size of the box.
Did you just use a single relay with a temp sensor and run both fans together?
My application is an E body with 26" radiator.
Chris
Re: Radiator/Fan Combo [Re: BcudaChris] #2467220
03/16/18 06:25 AM
03/16/18 06:25 AM
IN
ahy Offline
ahy  Offline
IN
I'll suggest a flex fan (mechanical) and custom shroud. Flex fans are not my favorite but can work if chosen well. I have a friend that runs one in a handling application and works OK. The flex fan should fit fine and custom shroud to direct the air. Lightweight also.
Mancini/Muscle Car Radiators can make the aluminum shroud. You fill out a diagram with measurements and they send the shroud.
Re: Radiator/Fan Combo [Re: ahy] #2467414
03/16/18 05:17 PM
03/16/18 05:17 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had a custom one made for my 70' Challenger. Even added -20 An Fittings for the upper & lower hoses. It is supporting almost 1000 H.P. om motor on the street.
1970 Challenger R/T, 528 Hemi
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Radiator/Fan Combo [Re: BcudaChris] #2468112
03/18/18 02:36 PM
03/18/18 02:36 PM
Lake Orion, MI
Lake Orion, MI
Chris
I used a Dakota Digital controller. The speeds are controlled by the resistor/diode pack in the lower driver's corner. The two connections on the motor are power and ground. If you don't use the resistor, you get the high speed. Wiring diagram (maybe not real pretty but accurate). My car has an autometer electric gauge so it uses that as a temp sender.
Both fans will start and run at the same time. But the low speed on its own works well.
