Re: WHO HAS THE MOST ORIGINAL LOOKING REPLACEMENT RADIATORS
[Re: Magnumguy]
#2462497
03/07/18 12:00 PM
03/07/18 12:00 PM
Posts: 43,517 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Glen-Ray Radiator out of Wausau, WI has the best but I am sure you mean aftermarket not reproduction.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Magnumguy]
#2462499
03/07/18 12:05 PM
03/07/18 12:05 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
I put an OER from Classic Industries in my 70' Charger last summer. Looks just like the OEM factory radiator but it just doesn't have the tank numbers stamped on top. Everything bolted right up as needed & hose location were in the correct positions as well. My car also will now idle all day in Woodward traffic and not overheat. I am happy with it so far.
I had a complete custom radiator made for my 70' Challenger to support the 1000 HP on the street. It has a custom made shroud & dual electric fans incorporated in it. I had them try to keep the Mopar look & had them add the -20 weld bungs for the AN fittings for the upper & lower hosed to keep with my "race car but looking kind of stock theme".
[Re: 6PKRTSE]
#2462500
03/07/18 12:07 PM
03/07/18 12:07 PM
Posts: 4,448 Morristown Tn.
71birdJ68
Morristown Tn.
That doesn't look anything like a factory radiator. To the OP, if you want one that look just like the original, call Glen Ray, but I'm not sure if they make all of the different styles that Chrysler used.
[Re: 71birdJ68]
#2462504
03/07/18 12:12 PM
03/07/18 12:12 PM
Posts: 18,157 Mass
DAYCLONA
Mass
That doesn't look anything like a factory radiator. To the OP, if you want one that look just like the original, call Glen Ray, but I'm not sure if they make all of the different styles that Chrysler used. He never said it was... But agreed on vendor Glen-Ray, but expect to spend $$$$ if the best is what you want Mike
[Re: DAYCLONA]
#2462508
03/07/18 12:22 PM
03/07/18 12:22 PM
6PKRTSE
Motor City
That doesn't look anything like a factory radiator. To the OP, if you want one that look just like the original, call Glen Ray, but I'm not sure if they make all of the different styles that Chrysler used. He never said it was... But agreed on vendor Glen-Ray, but expect to spend $$$$ if the best is what you want Mike Yes, I never said 100% correct. the rad in my Challenger isn't 100% correct I was just going for some thing close. As mentioned Glen Ray is the source for the 100 factory look but not everyone can spend $1500.00 on just a radiator.
[Re: Magnumguy]
#2462531
03/07/18 01:17 PM
03/07/18 01:17 PM
6PKRTSE
Motor City
It's not a show car, just a survivor/driver. I don't like the flat topped style like 6PKRTSE posted.
One Magnum I had had one, not sure where it came from.
I'll try these listed, thanks. I was just showing the rad in my Challenger as another option or comparison. The rad in my Charger is much closer to OEM.
[Re: Magnumguy]
#2462606
03/07/18 03:32 PM
03/07/18 03:32 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
I'll try these listed, thanks. Are you looking for ribs in a square top? or are you asking about a bubble top (aka round top) tank?
[Re: Magnumguy]
#2462868
03/07/18 11:11 PM
03/07/18 11:11 PM
Posts: 10,640 S.E.Ohio
Magnumguy
S.E.Ohio
Are you looking for ribs in a square top? or are you asking about a bubble top (aka round top) tank? Square is what's on it.
[Re: Magnumguy]
#2462916
03/08/18 12:50 AM
03/08/18 12:50 AM
Posts: 2,138 tucson az
frank
tucson az
