Page 1 of 2 1 2 >
#2462405 - 03/06/18 11:17 PM pics of electruc fuel set up underneath by the gas tank
mopar muscle7271 Offline
Loc: las vegas,nv
Im puttin a electric fuel pump in and i know goes by the gas tank.lookin for pics how you have yours set up and mounted underneath your mopars.its goin a in 71 dart with a 440.also using the mr.gasket fuel pump 95gph with the mallory fuel filter canister as well.
Edited by mopar muscle7271 (03/06/18 11:20 PM)
#2462426 - 03/07/18 01:22 AM Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271]
srt Offline
Loc: $0.6k+B
I'm curious too. I had one in a b body mounted in the trunk by p.o., removed it. Bought a new pump and see it's supposed to be mounted lower than fuel level. I'd also like to know if it can be mounted sideways or upside down to get ground clearance. May get a different pump that can be mounted above fuel level.
I bookemarked this link that had good info, esp. the oil pressure switch <- Click
#2462429 - 03/07/18 01:36 AM Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271]
SNK-EYZ Offline
Loc: Lost in Space
I seem to remember pics in the tread the first time you asked. whistling
http://board.moparts.org/ubbthreads/ubbt...tml#Post2434810
#2462453 - 03/07/18 07:06 AM Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271]
70HemiGTX Offline
Loc: PA
Great memory, just short.
#2462483 - 03/07/18 08:34 AM Re: pics of electruc fuel set up underneath by the gas tank [Re: SNK-EYZ]
Loc: las vegas,nv
That was legit...Don't be an ass and members will help you. tsk
Edited by tboomer (03/07/18 03:31 PM)
Edit Reason: rudeness
#2462509 - 03/07/18 09:23 AM Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271]
DaytonaTurbo Offline
Loc: Manitoba, Canada
Use a rubber isolated p-clamp to mount the pump. Mount it as close to the tank as you can, as low as you can. Unless you have a fuel cell in the trunk you're not going to get the pump below the tank, but if you can get the bottom of the pump close to flush with the bottom of the tank you're doing good IMO.
#2462662 - 03/07/18 01:46 PM Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271]
SNK-EYZ Offline
Loc: Lost in Space
Originally Posted By mopar muscle7271
Wasn't askin for any smartass remarks either.
If you think that's smartass, you've got a lot to learn. laugh2
Exactly how many times are you going to ask the same question?
If you haven't figured out how to mount the pump by now, you definitely need to have someone else install it.
#2462667 - 03/07/18 01:52 PM Re: pics of electruc fuel set up underneath by the gas tank [Re: markz528]
6PKRTSE Offline
Loc: Motor City
Mine is similar but I mounted mine through the floor with a mouting plate under so it is not just going through sheet metal in case of a roller over. I wanted mine in the trunk so it was up out of the way from the wheelie bars and away from rubber debris from underneath.
Edited by 6PKRTSE (03/07/18 01:53 PM)
1970 CHALLENGER R/T, 25.5 Cert, Big Inch Alum 16 plug HEMI twin turbo.
1970 Plymouth Road Runner.
1996 2500 RAM 488 V-10 4X4.
2012 Challenger R/T Classic.
#2462795 - 03/07/18 06:28 PM Re: pics of electruc fuel set up underneath by the gas tank [Re: 6PKRTSE]
68jim Offline
Loc: Southeast Virginia
I mounted this Carter pump in the axle tunnel just forward of the gas tank. I made a plate and used a couple of existing bolt holes so nothing was modified on the body. I use this pump as my primer pump to fill the carbs before starting car. This is a 68 B body with a dana 60 - still plenty of room. The hose coming from the tank to the pump is maybe 12" long.
Good luck with the project.
#2463512 - 03/08/18 10:29 PM Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271]
Loc: las vegas,nv
Anyone running the mr.gasket pumps or holleys?
#2464864 - 03/11/18 05:02 PM Re: pics of electruc fuel set up underneath by the gas tank [Re: 68jim]
mikemee1331 Offline
Loc: bethlehem pa
did the exact same thing with exact same pump. 69 B 8 3/4
#2467662 - 03/17/18 08:39 AM Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271]
383man Offline
Loc: Balt. Md
I run the Holley black pump. Its mounted right in front of the gas tank as since I run a stock gas tank its really nowhere to mount it lower then the tank. So its bolted on the floor right in front of the gas tank near the sending unit. Its actually sitting level with the top of my stock tank.
It has worked fine mounted there for 12 years so far as I put the car on the road in 2006. And it feeds enough fuel to my 850 carb for my 63 to run 10's and not lay over in the traps. I have not been able to get any pics as my left knee is real bad and my other joints have been giving me so much trouble its tuff to lay under the car and get a pic. I am actually getting my left knee replace this Monday on March 19th. Ron
My car...63 Sport Fury Max Wedge wanna be street car..with new 493 pump gas full exh eng.......10.76 @ 124.49 ! ! ! My page on the cool 62-65 Mopar site ! http://www.1962to1965mopar.ornocar.com/mmo82008.html
#2467666 - 03/17/18 08:53 AM Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271]
Bad340fish Online   content
Loc: Tulsa OK
I don't have a pic but before I went EFI I had a Holley Blue pump mounted in front of the spring mount on the passenger side. It worked well there for a very long time.
68 Barracuda Formula S 340
#2467811 - 03/17/18 04:40 PM Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271]
smos001 Offline
Loc: usa
On my 70 challenger, I put my electric pump right in front of the fuel tank. I made a bracket to have it hang a bit lower. I also found a thick rubber exhaust hanger material that I used to put behind the fuel pump and the bracket to reduce the noise and vibration.
Works great.
Edited by smos001 (03/17/18 04:40 PM)
#2467879 - 03/17/18 07:53 PM Re: pics of electruc fuel set up underneath by the gas tank [Re: 383man]
peabodyracing Offline
Loc: Minnesota
Ron, best of luck on your surgery. Knee replacement has come a long way in the past few years, so seems to get simpler all the time. Hope you're back up and running in short order. You're always a great help to us here with questions.
Lead, follow or get the hell out of the way
#2468408 - 03/18/18 10:30 PM Re: pics of electruc fuel set up underneath by the gas tank [Re: peabodyracing]
383man Offline
Loc: Balt. Md
Thank you as I go in tomorrow morning. Ron
#2468577 - 03/19/18 11:54 AM Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271]
moparmarks Offline
Loc: Western Colorado High Desert
Here is a Holley Black pump mounted on a plate off of the shock cross member. This is an E body with a Dana.
71 RR A/G 4-sp Dana, 72 SSP 440, 72 Dart 5.9 4-spd, 97 DAKOTA, amoung others.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
moparmark@bresnan.net
#2471193 - 03/23/18 10:49 PM Re: pics of electruc fuel set up underneath by the gas tank [Re: 383man]
Loc: las vegas,nv
Hope your surgery went well
#2471199 - 03/23/18 11:07 PM Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271]
Loc: las vegas,nv
Thanks for the tips i wil probably do the same mount in front of the tank.im runnin the stock tank to.any advice/pics how you wire it up?
#2471315 - 03/24/18 10:46 AM Re: pics of electruc fuel set up underneath by the gas tank [Re: mopar muscle7271]
jcc Online   content
No politics
Loc: Trumussia
It will take only one muscle car with a rear mounted exposed electric fuel pump to be involved in a fender bender with a loaded school bus for all this electric fuel DIYI upgrades to go legally bye bye. Taking that into account, installing one of these might save you and your car also.
https://www.summitracing.com/parts/rfw-cr92/overview/
Seeking more civil pastures
Page 1 of 2 1 2 >
25,339 Registered Members
190,119 Topics
Most users ever online: 1,393 @ 06/18/18 12:16 PM
1965 Plymouth 2 door post, big block , 4 speed --Minn 22,000
by bigdad
06/18/18 12:22 PM
1970 Super Bee right side brake line routing
by Cuda340
06/18/18 11:18 AM
4dr. guys- '71 Satellite for $2k in Tenn.
by I_bleed_MOPAR
06/18/18 11:09 AM
It ain’t an engine, but is described that way...
by 360view
06/18/18 11:08 AM
