Roller or Flat Tappet
#2453768
02/19/18 02:34 AM
02/19/18 02:34 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Hey guys, Have shat a roller lifter in my 528 indy headed wedge, it's in a 95% street 5% strip Barracuda, 600 rwhp , 4500+ stall, 3.7 gears and 28" tire. Now Im guessing the cam will be stuffed as well so was thinking maybe I just go for new solid flat tappet cam and lifters like my other engine. The roller cam that's in there was originally for the strip with a small shot of N20, 285 290 112lsa and 727 lift. Have to add a set of springs if I go new roller as they are on there way out but if I go for the flat tappet idea I have springs. So with this info what do you think I should go for ? Fell free to suggest cam specs if your keen. cheers
1963 Plymouth Max Wedge 1971 Barracuda
Re: Roller or Flat Tappet
[Re: ozymaxwedge]
#2453771
02/19/18 02:49 AM
02/19/18 02:49 AM
hemi-itis
I have been using roller lifters in the street for 20 years. What failed with your lifter? How old was it? Have you lashed them regularly,,at least 4 times year? What spring pressure were you using?
[Re: ozymaxwedge]
#2453777
02/19/18 03:02 AM
02/19/18 03:02 AM
ozymaxwedge
Australia
Have not pulled the top off yet, only a valve cover and there is a 1/2" of lash on #7 EX, push rod straight and adjuster is sweet. I guessing the roller is gone ? Springs were 240lb and 630lb when new but think they are more like 200lb now. Yeah they are about 8 years old.
[Re: ozymaxwedge]
#2453788
02/19/18 03:46 AM
02/19/18 03:46 AM
hemi-itis
With rollers,when you lash and find one needs an adjustment make note.heck,if that lifter is loose Next time you check than you know the lifter is going away.Rebiuld ALL the lifters,not just the loose one!
[Re: ozymaxwedge]
#2453877
02/19/18 12:44 PM
02/19/18 12:44 PM
Posts: 11,988 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
When you ask this question, you get a lot of different opinions. We can talk about spring pressures, oil, cam cores, lifter styles, lash, lifter maintenance, lifter brand, bushings vs bearings, etc, etc.
Certainly, which one to use depends on the intended use. The bigger the cam and the higher the necessary spring pressures that comes with that tends to favor the rollers.
For my primarily street Hemi, low maintenance and durability was very important. I talked to several major Mopar engine builders about which style cam to run.
For me, Ray Barton's recommendation of the tool steel flat solid tappet was the best choice. And it has worked well.
Master, again and still
[Re: DaveRS23]
#2453942
02/19/18 03:07 PM
02/19/18 03:07 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
For me, Ray Barton's recommendation of the tool steel flat solid tappet was the best choice. And it has worked well. Not trying to be a smart a--, but have you checked the cam lobe nose ? me and others did not fair so well with tool steel lifters. I was going solid roller, I now am going with the Morel High RPM, push rod oil, Hydro roller. HUG 6074 BB RACE HYDRAULIC ROLLER LIFTER SET GOOD FOR UP TO 225# SEAT PRESSURE & 550# OPEN $919.47 Set of 16 Big Block Hydraulic Race Roller Lifters. These are oil thru lifters and will oil through the pushrods if you need them to. Suggested maximum spring pressure: 225# on the seat 550# full lift DO NOT RUN OIL THICKER THAN 5W40 WITH THESE LIFTERS. .810" roller * The lifter bores do not need to be bushed to run these lifters. * DO NOT use these lifters with a flat tappet cam! Note: These lifters also fit the AMC V8 engines.
[Re: ozymaxwedge]
#2453955
02/19/18 03:27 PM
02/19/18 03:27 PM
Posts: 11,479 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Another roller all day long. 8 years on springs? If they've lost 20% on the seat, what are they doing over the nose? Gotta maintain this stuff.
[Re: ozymaxwedge]
#2454053
02/19/18 06:38 PM
02/19/18 06:38 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
Al, my which aren't worth much . If primarily street and you want a roller go hydraulic . BUT this will limit rpm to around 6500 max. You may want to go to a 30" tyre , several guys I know run 30" radials on their E bodies I myself like solid flat tappet because I like simple , plus they don't get wound up with extended traffic idleing . Though can be a gamble with break in . I do not have the same choof your motor does . Current flat tappet is a custom grind from Crow Cams , nitrided and I use Howards lifters with oil hole . This is the second motor with Howards lifters , no issues . Tex
[Re: CSK]
#2454144
02/19/18 09:22 PM
02/19/18 09:22 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
For me, Ray Barton's recommendation of the tool steel flat solid tappet was the best choice. And it has worked well. Not trying to be a smart a--, but have you checked the cam lobe nose ? me and others did not fair so well with tool steel lifters. I was going solid roller, I now am going with the Morel High RPM, push rod oil, Hydro roller. No, I haven't checked the cam in a couple of years. I check the lash every 1,000 miles or so and it hasn't changed. Are you saying that the nose goes away while the ramps and base circle are okay? Ray Barton has built more of these engines that about anyone around and he said that he sees less problems from the flats than from the rollers on the street. One big reason is the closer tolerance machining on these lifters than on many other flat tappet lifters. If any of the lobes go away, I will definitely let everybody know.
[Re: DaveRS23]
#2454173
02/19/18 10:23 PM
02/19/18 10:23 PM
CSK
Pattison Texas
For me, Ray Barton's recommendation of the tool steel flat solid tappet was the best choice. And it has worked well. Not trying to be a smart a--, but have you checked the cam lobe nose ? me and others did not fair so well with tool steel lifters. I was going solid roller, I now am going with the Morel High RPM, push rod oil, Hydro roller. No, I haven't checked the cam in a couple of years. I check the lash every 1,000 miles or so and it hasn't changed. Are you saying that the nose goes away while the ramps and base circle are okay? Ray Barton has built more of these engines that about anyone around and he said that he sees less problems from the flats than from the rollers on the street. One big reason is the closer tolerance machining on these lifters than on many other flat tappet lifters. If any of the lobes go away, I will definitely let everybody know. The lash never changed on mine 4000 ish miles, the nose goes away. link to my post LINK HERE TO MY CAM PROBLEM
[Re: CMcAllister]
#2454208
02/19/18 10:58 PM
02/19/18 10:58 PM
ozymaxwedge
Australia
Another roller all day long. 8 years on springs? If they've lost 20% on the seat, what are they doing over the nose? Gotta maintain this stuff. Yeah I know but $$$$.. The 8 years was how old the roller lifters are, springs about 4 years.
[Re: DaveRS23]
#2454218
02/19/18 11:03 PM
02/19/18 11:03 PM
ozymaxwedge
Australia
For me, Ray Barton's recommendation of the tool steel flat solid tappet was the best choice. And it has worked well. Cheers Dave, I guess that the cost probably answers my question, the extra coin purchasing and ongoing spring/lifter replacement is swaying me toward a flat tappet.
[Re: ccdave]
#2454273
02/19/18 11:42 PM
02/19/18 11:42 PM
ozymaxwedge
Australia
Install a Hyd roller with beehive springs and forget it’s there. Will run and perform flawlessly for many years Will I give up some horsepower ? A bit more would be nice. Like to recommend some numbers ?
[Re: ozymaxwedge]
#2454278
02/19/18 11:49 PM
02/19/18 11:49 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I use solid flat tappets because of the cost, simplicity and reliability.....it cost some hp but just a street/sptip car.
Have a great day Iowan
"obsolete is neat"
[Re: ozymaxwedge]
#2454487
02/20/18 12:32 PM
02/20/18 12:32 PM
Posts: 13,345 Marion, South Carolina [><]
an8sec70cuda
When I built my 572" hemi 12 years ago, the two main guys I consulted w/ during the planning phase both recommended me to go w/ a flat tappet cam b/c of all the street use it was gonna see. I stuck to my guns and went solid roller and have never once been upset about it. If you buy GOOD parts, you'll be fine. Yes, the roller is definitely more expensive, but so is going through an engine again after a lobe goes flat. You can't run a big nasty solid roller lobe w/ $400 lifters and expect it to live long.
[Re: ozymaxwedge]
#2454511
02/20/18 01:04 PM
02/20/18 01:04 PM
Posts: 1,807 Mopar Country, Mi
ccdave
The Ultimate
The Ultimate
Mopar Country, Mi
Install a Hyd roller with beehive springs and forget it’s there. Will run and perform flawlessly for many years Will I give up some horsepower ? A bit more would be nice. Like to recommend some numbers ? I'm going by your 95% street driven. Will you give up some power? Maybe a little. Do you want your valve train to last for years and not have to fiddle with it??? I would recommend Hughes cam# SER6064BL3-9 with PAC 1220 springs. Most here will consider this cam small for your application but the key word is "95% street"
