Re: 18 spline speed gear bushings
[Re: moparpoolman]
#2453241
02/17/18 10:54 PM
02/17/18 10:54 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Does anyone know where to get A 833 18 spline speed gear bushings? Has anyone changed them before, any tricks? Thanks I have never had to change one before what's wrong with yours? Gus
[Re: moparpoolman]
#2454005
02/19/18 04:50 PM
02/19/18 04:50 PM
Posts: 766 Ohio
Dan Brewer
Ohio
Thanks for the reply Dan, the bushing does seem to be a little worn so if I was going to mess around with it I think I'd rather spend the time replacing it. Are the Bushings available? Do You sell them? Thanks I don't have any new ones left. I probably have a damaged gear that has a good bushing if you want to do it that way.
