Re: Heater Core?
[Re: 70sixpkrt]
#2452717
02/16/18 07:09 PM
02/16/18 07:09 PM
Posts: 3,675 South San Francisco, Ca
70sixpkrt
The reservoir bucket is full but the radiator was a little low. I always check the reservoir bucket instead of the radiator. Need to check the radiator instead of the bucket for now on. Need to change coolant next week.
Re: Heater Core?
[Re: ahy]
#2453298
02/18/18 01:12 AM
02/18/18 01:12 AM
70sixpkrt
Might be a good idea to change the cap also... and make sure the line to the reserve/overflow tank is in good shape and well attached.
Normally, keeping the reserve tank full should get you a full radiator after a few heat/cool cycles. if the cap is bad or leak in the line, that may explain why radiator level was low. Good idea.
Re: Heater Core?
[Re: 70sixpkrt]
#2453312
02/18/18 01:38 AM
02/18/18 01:38 AM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
Does it have AC? Could be water from the evap core not draining.Even when cool and running defrosters over 32 degrees the AC comes on with defrost.Rocky
Chrysler Firepower
Re: Heater Core?
[Re: 70sixpkrt]
#2453681
02/18/18 11:22 PM
02/18/18 11:22 PM
Posts: 3,462 Back in NJ....
EWJ
Back in NJ....
I have the same sound each time I start my 01 Cummins- and just been living with it. Will swap out the cap, check the rad level and go from there.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Heater Core?
[Re: poorboy]
#2455410
02/22/18 01:53 AM
02/22/18 01:53 AM
70sixpkrt
It won't pull the coolant from the reservoir bucket back into the radiator if there is a leak in the system. The reservoir system relies on the vacuum the escaping coolant creates when it pushes the coolant into the reservoir, in order to pull it back into the radiator. A leak in the system bleeds off the vacuum before it can pull the coolant back into the radiator. Something as simple as the coolant in the reservoir tank being below the inlet from the radiator can result in not pulling the coolant back into the radiator.
The reservoir system is a great addition, but at least a few times a year I will pull the cap when the motor is cold to be sure the radiator is full. That is the result of an expensive lesson learned years ago. Gene Thanks for the explanation.
Re: Heater Core?
[Re: 70sixpkrt]
#2459047
02/28/18 08:19 PM
02/28/18 08:19 PM
Posts: 855 ontario canada kingston
aspenrt360
air in system had the same odd sound i burped the system problem solved. at least it was for me.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
