Re: BB Water Pump
[Re: 71birdJ68]
#2451631
02/14/18 12:55 PM
02/14/18 12:55 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
Three core aluminum Champion radiator, Milodon 160 degree high flow stat, cheap OEM aluminum water pump and twin Ford Contour electric fans. Hold my 512 stroker at 180 degrees on the hottest of summer days. Would go cooler if I set the controller lower.
Re: BB Water Pump
[Re: 71birdJ68]
#2451677
02/14/18 03:00 PM
02/14/18 03:00 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
It will run 210/215 on a hot day. I know everybody says that that temp is ok, but I have the rad off for some other things, so I thought if a pump upgrade would lower it a few degrees, then I would give that a try. OEM A/C set-up on a '71 Ply B-body... Including A/C water pump w/180 thermo... Years of extreme driving conditions... Including a lot of summer putt-putt in traffic... NEVER gone past 180...
Re: BB Water Pump
[Re: 71birdJ68]
#2452676
02/16/18 06:05 PM
02/16/18 06:05 PM
It will run 210/215 on a hot day. I know everybody says that that temp is ok, is that around town or on the highway? & the reading is confirmed with a good mech gauge. Any overheating symptoms other than what the current gauge is showing (& I ain't saying 210 is critical).
Re: BB Water Pump
[Re: 71birdJ68]
#2452933
02/17/18 04:05 AM
02/17/18 04:05 AM
Posts: 21,814 Kirkland, Washington
Pacnorthcuda
All I asked was, if anybody knew of a 8 vain pump with aaa anti cav plate all ready installed. Don't forget the Aluminum requirement! And You're So Vain, you probably think this thread is about you, don't you? 8 vane. All good LOL
Re: BB Water Pump
[Re: 71birdJ68]
#2456625
02/24/18 01:14 PM
02/24/18 01:14 PM
Posts: 64 MA
Kevin Kowalski
MA
There are several 6 vanes with a anti cal plate. I'm looking to up grade. Guess I could get a Mildon, which has 8, and add a plate. I read this post before ordering a Milodon #16260 high volume pump which I received yesterday. To my surprise it has a welded anticavitation plate and 6 vanes. The op also described his current one as a 6 blade with the anticav plate. For reference the pump has 'GMB' and 'CR20' cast on the front.
