Re: Pushrod Holes in Magnum Heads
[Re: jeebis44]
#2439811
01/24/18 12:38 AM
01/24/18 12:38 AM
I would mockup with some light springs & just eyeball how much clearance you have like in Joesixpacks' nearby thread then dremel em out as needed. set the heads down easy on the head gaskets & barely snug each head with several head bolts & mockup the valvetrain & turn the crank over with a 1&1/4" socket/breaker bar.
[Re: jeebis44]
#2439812
01/24/18 12:38 AM
01/24/18 12:38 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have never had to clearance them, done a bunch and even with one like an R/T head with a machined hole never had to clearance one.
[Re: jeebis44]
#2440189
01/24/18 07:16 PM
01/24/18 07:16 PM
Posts: 1,231 Chicago, IL
PLUM_72
Chicago, IL
Wasn't there a magnum head template floating around between the forum users to drill this out?
1972 Dodge Challenger
[Re: jeebis44]
#2440351
01/25/18 01:49 AM
01/25/18 01:49 AM
HotRodDave
Kalispell Mt.
the template is for porting, there was a jig for doing the intake bolt holes, I never had an issue with PR clearance but I have also never tried to run them with anything bigger diameter than a stock one. If there is an issue it can't be much just mark it and grind it a bit with a dremmel.
[Re: jeebis44]
#2440363
01/25/18 02:13 AM
01/25/18 02:13 AM
Posts: 14,889 up yours
Supercuda
Been my observation that roller heads have bigger pushrod holes than flat tappet heads so I wonder why you'd need to open up the magnums?
