Compresion Check #2439015
01/22/18 03:00 PM
01/22/18 03:00 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Sticking together a new shortblock and just would like to see if I have all my calculations figured out before I purchase head gaskets.
440 block
3.75 stock crank
.040 over Ross flat tops 2 valve reliefs (3 CC) .002 in the hole
Eagle H Beam rods
Trick Flow 240 heads (78cc chambers)
Using a Cometic 4.380 board gasket .045 thick
I come up with 10.91:1
Re: Compresion Check [Re: DusterKid] #2439062
01/22/18 04:05 PM
01/22/18 04:05 PM
RapidRobert Offline
RapidRobert  Offline
that's what I got
