Re: Best bang for the buck 440 heads and rods
[Re: Cab_Burge]
#2440409
01/25/18 04:08 AM
01/25/18 04:08 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: Twostick]
#2440623
01/25/18 04:48 PM
01/25/18 04:48 PM
Posts: 43,095 Bend,OR USA
Does he know the bore and stroke on that motor? Please find out and if he does please post it on here
[Re: Skeptic]
#2440656
01/25/18 05:58 PM
01/25/18 05:58 PM
Posts: 3,443 Northern N.J.
hemi_doug
Northern N.J.
So many Chebby guys have no clue that Chrysler built a 383 that wasn't a stroker. Actually, it kinda was...it began as a 361 I believe....
71 440-6 4spd & 69 Hemi 4spd
[Re: hemi_doug]
#2440763
01/25/18 11:15 PM
01/25/18 11:15 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
So many Chebby guys have no clue that Chrysler built a 383 that wasn't a stroker. Actually, it kinda was...it began as a 361 I believe.... by that "logic" a 440 is a stroker motor too. Still isn't a [censored] Chevy.
[Re: Cab_Burge]
#2440769
01/25/18 11:31 PM
01/25/18 11:31 PM
Posts: 1,880 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
Does he know the bore and stroke on that motor? Please find out and if he does please post it on here Cab,All RB's are 3.75" stroke stock.I had to look up the bore dimension,I found 4.03" for the RB 383 engine. RT
[Re: Skeptic]
#2440792
01/26/18 12:09 AM
01/26/18 12:09 AM
hemi_doug
Northern N.J.
So many Chebby guys have no clue that Chrysler built a 383 that wasn't a stroker. Actually, it kinda was...it began as a 361 I believe.... by that "logic" a 440 is a stroker motor too. Still isn't ag [censored] Chevy. Nope..not the same block...not being a Chevy aside.
[Re: dodge turbo]
#2440870
01/26/18 03:47 AM
01/26/18 03:47 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I also have a good friend with an all original 60 Windsor wagon with a 383 RB. 3.75 stroke
[Re: hemi_doug]
#2440882
01/26/18 05:44 AM
01/26/18 05:44 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
So many Chebby guys have no clue that Chrysler built a 383 that wasn't a stroker. Actually, it kinda was...it began as a 361 I believe.... It actually began as a 350 then 361 to 383 and then 400. I had heard the RB 383 was built for two years but I am not 100% sure on that. Ron
[Re: 383man]
#2441154
01/26/18 07:38 PM
01/26/18 07:38 PM
hemi_doug
Northern N.J.
So many Chebby guys have no clue that Chrysler built a 383 that wasn't a stroker. Actually, it kinda was...it began as a 361 I believe.... It actually began as a 350 then 361 to 383 and then 400. I had heard the RB 383 was built for two years but I am not 100% sure on that. Ron thank you sir, I stand corrected...
