Media blasting challlenger grill #2438588
01/21/18 08:11 PM
01/21/18 08:11 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Would media blasting this part of the grill leave a good finish for painting. It's an RT grill, painted black.
Re: Media blasting challlenger grill [Re: varunner] #2438871
01/22/18 05:28 AM
01/22/18 05:28 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
If it's cured i.e. aged lacquer, & a reasonably thin coating, then a very fine glass bead media would remove it at lowest possible pressure. If enamel, blasting is more difficult, since it's not as brittle as lacquer. But that metal is slow thin, warpage/distortion is likely, unless maybe you blast at a shallow angle.
Better to get some lacquer thinner & 0000 steel wool & scrub it away. 0000 wool works nice on anodized stuff.
Re: Media blasting challlenger grill [Re: PhillyRag] #2438876
01/22/18 06:29 AM
01/22/18 06:29 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Did you try paint stripper? Let it go for a few minutes then take a scrub brush to it.
Re: Media blasting challlenger grill [Re: varunner] #2438890
01/22/18 09:58 AM
01/22/18 09:58 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Don't know what type of paint it is, looks thick. I'll try a stripper
Re: Media blasting challlenger grill [Re: varunner] #2440463
01/25/18 11:19 AM
01/25/18 11:19 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Tried a jasco stripper, took the black off easily, underneath is argent which is harder to remove. Evidently it's not an R/T grill ?
