Re: NEED STROKER ADVISE
[Re: frank]
#2439238
01/22/18 10:27 PM
01/22/18 10:27 PM
Posts: 1,030 ohio
67mprfan
ohio
Yes feel free to ask questions that's how we all learn, plus a lot of folks have been there and done that
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: frank]
#2439363
01/23/18 02:32 AM
01/23/18 02:32 AM
Posts: 4,663 Wichita
GY3
Wichita
I'd like to thank all who replied. I appreciate the information. I wasn't planning on EFI but I don't have a problem with it. In tank pump and return already in the car. I'm leaning toward the RPM intake. How tall it sits on these heads will be the deciding factor. I know a SD will fit. Final question on the rockers. I've researched the previous posts and links and I'm still not sure which ones to look closer at. For the guys using these heads what rockers are you using and are you happy with them. Thanks again I used a brand new set of Crane ductile iron I found for $100. No moving parts or bearings to cause problems and no aluminum to fatigue. I follow KISS.
[Re: frank]
#2439407
01/23/18 04:21 AM
01/23/18 04:21 AM
Posts: 43,096 Bend,OR USA
For the guys using these heads what rockers are you using and are you happy with them. Thanks again Which heads are you buying? Don't go for the cheapest rockers you can get because that is what you will get Buy the best ones YOU can afford You only have to buy one set of good rocker arms, not three sets of cheap ones BTW, I am probably the only guy on here that was born smart, my grandfather told me to buy Chrysler products from day one AKA aside, most of us, not all of us though , on here are here to help any one asking for it
[Re: Cab_Burge]
#2439768
01/23/18 10:36 PM
01/23/18 10:36 PM
Posts: 2,138 tucson az
frank
tucson az
For the guys using these heads what rockers are you using and are you happy with them. Thanks again Which heads are you buying? Don't go for the cheapest rockers you can get because that is what you will get Buy the best ones YOU can afford You only have to buy one set of good rocker arms, not three sets of cheap ones BTW, I am probably the only guy on here that was born smart, my grandfather told me to buy Chrysler products from day one AKA aside, most of us, not all of us though , on here are here to help any one asking for it I've decided to go with the 240 heads. I talked to my machinist and he likes those also. I can afford good parts but I want the right parts. This is my last big engine and I want it right the first time.
[Re: dogdays]
#2440556
01/25/18 02:32 PM
01/25/18 02:32 PM
Posts: 14,491 So. Burlington, Vt.
I believe Harland Sharp has come out with a new KE Series rocker specially for the Trick Flow heads. IIRC it is shorter in length.
R. Actually, the "E" is for Edelbrock(they were available prior to the TF heads existing)...... And yes, they're a bit shorter. .060 IIRC. They are also the correct ones to use with the TF heads.
