U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios
#2437702
01/19/18 10:46 PM
01/19/18 10:46 PM
Posts: 904 cleveland Ohio
mloboda
cleveland Ohio
US GEAR is now making Pro Gear DANA 60 ring and pinions in these formally unavailable ratios( like not made in the last 20 + years)
5:57
5:86
6:17
Now they just need to add 6:50s !
Thanks US GEAR for keeping the Dana 60 from becoming obsolete!!!!!!!!!!!!!!!!!!!!!!
Re: U.S. GEAR now making Dana 60 progear 5:57 5:86 6:17 ratios
[Re: greendart408]
#2437788
01/20/18 01:47 AM
01/20/18 01:47 AM
Posts: 20,158 PA.
pittsburghracer
I would flip my car over with a set of those. LOL
[Re: mloboda]
#2437832
01/20/18 04:04 AM
01/20/18 04:04 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
5:57
5:86
6:17
Thanks US GEAR for keeping the Dana 60 from becoming obsolete!!!!!!!!!!!!!!!!!!!!!! Where the heck are you coming from on this?? No, No, No Drag racers need this steep of gears. ???? Drink another beer and go to bed. Now Mud bog races, maybe a good thing.??
[Re: RTSrunner]
#2437877
01/20/18 12:01 PM
01/20/18 12:01 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I guy I work with has a 69 Camaro with 6.00 gears in it. It is a 496 ci. Big block Chevy and he sprays it with a 250 shot of Nitrous. He said it runs 5.20's in the 1/8. I thought that was way too low a gear for Nitrous.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Sport440]
#2437880
01/20/18 12:15 PM
01/20/18 12:15 PM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
5:57
5:86
6:17
Thanks US GEAR for keeping the Dana 60 from becoming obsolete!!!!!!!!!!!!!!!!!!!!!! Where the heck are you coming from on this?? No, No, No Drag racers need this steep of gears. ???? Drink another beer and go to bed. Now Mud bog races, maybe a good thing.?? They are doing this because everyone now wants to run 1/8 mile (half a race) but now want to try and use all their engine to get there quicker. Yep - less breakage that way and yes that is why they are making them!
[Re: D-50]
#2437908
01/20/18 01:21 PM
01/20/18 01:21 PM
cudaman1969
fredericksburg,va
I guy I work with has a 69 Camaro with 6.00 gears in it. It is a 496 ci. Big block Chevy and he sprays it with a 250 shot of Nitrous. He said it runs 5.20's in the 1/8. I thought that was way too low a gear for Nitrous. Think about it, tight converter you need that gear reduction. Have you seen what gear the pro stock boys run? Most mopar engines are dead at 6000 (I know there are a few who buzz them) so I guess they only need those 4.10 gears. What gets me is you have a head that flows 500 cfm and you turn it 7000, a lot left on the table.
[Re: Sport440]
#2437927
01/20/18 01:43 PM
01/20/18 01:43 PM
Posts: 1,169 MI
68shifter
MI
5:57
5:86
6:17
Thanks US GEAR for keeping the Dana 60 from becoming obsolete!!!!!!!!!!!!!!!!!!!!!! Where the heck are you coming from on this?? No, No, No Drag racers need this steep of gears. ???? Drink another beer and go to bed. Now Mud bog races, maybe a good thing.?? You better go watch Mike's small block then. It's not some lazy J headed or even w2 setup. I bet his tach starts at 6k.
[Re: mloboda]
#2437930
01/20/18 01:48 PM
01/20/18 01:48 PM
Posts: 5,894 Florida
Locomotion
I know a guy with a Super Stock 318 Aspen that uses mid-high 5.xx ratios and it wouldn't surprise me if a 5.38 could be used in a Stock class 340 stick car in the 1/4. Heavier cars can sometimes use more ratio also.
Maybe enough people are getting away from the more expensive and less efficient Ford 9", making these Dana 60 ratios worthwhile to manufacture.
Comp cars and what use to be Modified production like all that ratio too with their itty bitty engines.
[Re: Sport440]
#2437943
01/20/18 02:09 PM
01/20/18 02:09 PM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Where the heck are you coming from on this?? No, No, No Drag racers need this steep of gears. ???? Drink another beer and go to bed. Now Mud bog races, maybe a good thing.?? We have run a 5:56 Dana for longer than I can remember in a drag race car. It is not unusual to see folks looking for the ratios above for drag race cars. With 32 and 33 inch tall tires the effective ratio is higher than you would think.
[Re: mloboda]
#2439039
01/22/18 03:36 PM
01/22/18 03:36 PM
Posts: 13,355 Marion, South Carolina [><]
an8sec70cuda
Even w/ big tires on an 1/8 mile car, I don't know anyone running anywhere near that much gear. We ran a 5.00 gear in the Camaro with 436" sbc, glide and 29.5x10.5 tires. Turning about 7400 rpm.
[Re: cudaman1969]
#2439041
01/22/18 03:37 PM
01/22/18 03:37 PM
an8sec70cuda
[Think about it, tight converter you need that gear reduction. Not w/ the nitrous on you don't.
