Fiberglass parts.
#2437440
01/19/18 01:35 PM
01/19/18 01:35 PM
Posts: 252 southeast ky
mills.mopar
southeast ky
Anyone have any experience with buying fiberglass parts?
I'm looking for a dash, rear bumper and brackets for 68 dart. I understand most parts are not perfect, but also don't want pure junk... If it matters is for a race only car... Let's here your experiences good or bad. Thanks Jeff
If you love it lube it
68 dart 37 dodge coupe 71 challenger
Re: Fiberglass parts.
[Re: mills.mopar]
#2437501
01/19/18 03:12 PM
01/19/18 03:12 PM
Silver70
Rust Belt, SW PA
You'll find people will like and complain about the same placs/parts... I've bought from Unlimited and it was a nice, but other say they only make junk.
[Re: Silver70]
#2437535
01/19/18 04:05 PM
01/19/18 04:05 PM
Posts: 43,096 Bend,OR USA
You'll find people will like and complain about the same placs/parts... I've bought from Unlimited and it was a nice, but other say they only make junk. Unlimited use to make junk before the company was bought and relocated to the High desert in SO CA ten + years ago. Bad reputation die hard I've bought and use two hoods from them, good stuff now
[Re: mills.mopar]
#2437714
01/19/18 11:05 PM
01/19/18 11:05 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
B1 is no longer in the dash business.... I have one in my stash of stuff. not sure when it will get installed. Jeff Lingenfelter makes some nice aluminum brackets for glass bumpers.... in case your fab skills are limited and you like nice stuff (describes me to a "T"). http://lingenfeltersbrackets.com/I had a VFN hood on the Duster when I got it from my dad with a Harwood 5" cowl grafted to it. Not sure how much work went into it, but it was REALLY nice in the fit and finish department.... buuuuuttt is weighed like 37Lbs. I installed an Unlimited "lightweigh" hood on it last fall. You could literally see daylight through it. Painted it weighs just a bit over 14lb. fit and finish not as nice, but it's "racecar" good enough!
