Who makes a good aluminum straight vane B/RB water pump?
#2436894
01/18/18 03:44 PM
01/18/18 03:44 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I was looking at going to a serpentine belt drive on the Imp but the 440 source water pump I got has a spiral vane impeller. That's a bit inefficient when the pump spins backwards.
Since the WP housing, cylinder heads, intake, and accessory brackets will be aluminum I thought I'd stick with an aluminum pump, too.
I had a Milodon years ago but it leaked from day one.
Any good leads for pumps that aren't needlessly expensive?
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
Re: Who makes a good aluminum straight vane B/RB water pump?
[Re: feets]
#2436963
01/18/18 05:48 PM
01/18/18 05:48 PM
feets
Senior Management
Senior Management
Irving, TX
I remember that thread well. However, much time has elapsed and manufacturers enter and leave the game.
The pump flow was not the concern. I'm looking for an aluminum body and a straight vane impeller.
The spirally vane I have works fine until you spin it backwards. That's when it gets a bit sketchy.
[Re: Jerry]
#2437296
01/19/18 02:38 AM
01/19/18 02:38 AM
that is an interesting thread. I would get an 8 blader & weld on the anticav plate with a 1.33 or more overdriven pulley & call it good. not sure what brand but after reading the thread I think a person could make an informed decision (just me I've had good luck with parts house rebuilts). & the rest of the cooling items correct, fan/shroud/spacer/radiator/stat/timing/mixture.
[Re: Azzkikrcuda]
#2437351
01/19/18 09:41 AM
01/19/18 09:41 AM
Posts: 619 nj
JAMESDART
nj
Yeah the gmb or whatever it's called is What flowkooler attaches their plate to. They are made in Japan from what I remember. I've had both and was a little disappointed when I tried the gmb and realized that.
[Re: Azzkikrcuda]
#2438996
01/22/18 02:26 PM
01/22/18 02:26 PM
feets
Senior Management
Senior Management
Irving, TX
Thanks for the info. That is the aluminum housing, correct?
[Re: feets]
#2439000
01/22/18 02:36 PM
01/22/18 02:36 PM
Posts: 21,063 Niles , Ohio
therocks
Niles , Ohio
I have the MP unit on my 440.Been there for close to 20 years.No problems and cools great.Rocky
Chrysler Firepower
[Re: feets]
#2439277
01/23/18 12:06 AM
01/23/18 12:06 AM
Posts: 14,889 up yours
Supercuda
Dude, you have an entire machine shop.
[Re: Jerry]
#2439289
01/23/18 12:24 AM
01/23/18 12:24 AM
Posts: 727 Michigan
BlueRacer69
we also make an overdrive water pump pulley for those guys with cooling problems. Where can I find one of these overdrive water pump pulleys that you mention? Thanks.
[Re: Supercuda]
#2440521
01/25/18 01:27 PM
01/25/18 01:27 PM
feets
Senior Management
Senior Management
Irving, TX
Sadly, I have to balance life, job, and a disturbingly long list of projects. I'm only one man with very limited time. Besides that, I have a full ground-up roadster build I need to get going.
[Re: Jerry]
#2440527
01/25/18 01:32 PM
01/25/18 01:32 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
we also make an overdrive water pump pulley for those guys with cooling problems. Link to the pulley?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
