Re: 1970 Cuda shaker hood emblem
[Re: AARCONV]
#2438629
01/21/18 09:11 PM
01/21/18 09:11 PM
Posts: 5,106 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Shaker 3 pins , the pins are tapered thicker and longer, from 1st pin to last pin the length of 2 pin emblems are alittle longer from hole to hole..very slight.. That is what I was saying above but the last two pin Cuda440-6 from Chrysler I have has the same dimension or distance between the first to last pin as a shaker emblem but has the small pins, both thinner and shorter like a sport hood emblem. The sport hood emblem from the first pin to the last pin should be just a little bit longer but these last Cuda440=6 emblems match a shaker emblem.
1971 HEMI E BODY REGISTRY
[Re: floyd]
#2438900
01/22/18 10:33 AM
01/22/18 10:33 AM
Posts: 2,294 Land of 10,000 Lakes
44D6PAKCUDA
I donāt think there is any difference other than the number/type of pins on cuda shaker emblems. The Challenger shaker emblems for 440-6 and hemi were different than what was on the bulge hood. Not sure if cuda 440-6 shaker emblems are reproād. Mitchelll motors has some āNOSā ones listed on eBay but I think Frank Mitchell had a bunch of emblems reproād years ago and sold as NOS. Either way they may be the only game In town. I am sure there is a different part number for the shaker emblems. https://www.ebay.com/itm/1970-1971-Plymo...Par/7994022972?Be aware that pins on the shaker emblems are longer and thicker than normal pins. The picture shown on the eBay ad have the correct brushed finish,but Mike will tell you that the ones Frank had repopped,and the ones you will receive have a chrome finish.Frank told me he had the same compamy repop these for him but they couldn't or didn't want to do the brushed finish.
[Re: 44D6PAKCUDA]
#2438928
01/22/18 12:07 PM
01/22/18 12:07 PM
Posts: 1,129 Home of the Bluegrass
MoparJunkie
Shaker emblems are thicker on the edges on one end to make them appear flat on the round shaker surface, and regular hood emblems are flat.
"It takes a Mopar to catch a Moparā 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
[Re: MoparJunkie]
#2439087
01/22/18 04:59 PM
01/22/18 04:59 PM
hemicar1971
Chicago Blackhawks
Shaker emblems are thicker on the edges on one end to make them appear flat on the round shaker surface, and regular hood emblems are flat. This is only on DODGE Shaker emblems.
