Re: Lemon Twist / Base Clear
[Re: GRAYBO]
#2436243
01/17/18 12:26 PM
01/17/18 12:26 PM
Posts: 18,157 Mass
DAYCLONA
Mass
What is the best match to Lemon twist yellow in a modern day base clear? And...Does anyone have a problem with a total restoration using modern day paints? Color match is not an issue if you have a competent mixer and purchase quality products and perform a spray out before application, the question is what finish do YOU desire on the vehicle, single stage, BC/CC?
[Re: Morty426]
#2436250
01/17/18 12:31 PM
01/17/18 12:31 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The biggest problem that I have seen with them has been color match. Most of them come out to light. If you can get them to match color you should be OK Color matches are off for most of the major suppliers in the last decade or so due to trying to simplify the computer mix programs, this means reducing or eliminating ALTs, or combining the ALTs for a single formula, or the merging of paint formulas that were used by several different auto mfgs, past and/or present into a single formula for the consumer mike
[Re: DAYCLONA]
#2436259
01/17/18 12:42 PM
01/17/18 12:42 PM
Posts: 20,478 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
PPG toners for yellow have been altered in the last few years for base-clear so expect the colors to be off. The single stage components are still ok.
If you want oem looking paint you should do it with acrylic enamel and spray it and leave the orange peel alone. Corvette guys who are serious still track down lacquer paint because that is what the factory used.
Base-clear wetsanded and buffed out does not look like the factory paint job. If you have a super rare and highly expensive car you want to sell to make money on later then the contemporary base-clear finishes should be off the list.
[Re: belv2vert66]
#2436373
01/17/18 04:07 PM
01/17/18 04:07 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
As Mike said the BC vs OE thing is a matter of taste. As far as color match none of the suppliers will have a stock mix that is right. I always get something close and fiddle with sprayouts. Sometimes as many 8 or 9 to get it to match an area that is untouched on that particular car. Under the windshield gasket is the best place if it has not been out. I think I have a Chroma Base formula for FY1 I did many years ago if interested. Be advised though different days/plants can have different shades of the same color. Another reason to match every car.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#2436407
01/17/18 04:48 PM
01/17/18 04:48 PM
Posts: 2,070 CA
crackedback
CA
Be advised though different days/plants can have different shades of the same color. Another reason to match every car. This is so true. Having one of the "experts" tell a guy that his original owner car must have been repainted because it wasn't real B5 blue was hysterical. There is a standardized mix formula but no "true" correct color because of variations between plants.
[Re: GRAYBO]
#2436408
01/17/18 04:49 PM
01/17/18 04:49 PM
Posts: 8,392 Highland, MI.
Sunroofcuda
Highland, MI.
Personally, I would do base/clear & a very light #2000 wet sand to knock down any dust or impurities that settle in the clear, but DO NOT flat-sand if you want to retain the factory orange peel look, which I prefer for an "original" looking finish. The sucked-glass look is nice, but too 'show car' for me.
