water pump removal #2435956
01/16/18 10:27 PM
01/16/18 10:27 PM
South-east Mn
blaze Offline OP
blaze  Offline OP
South-east Mn
I have a '95 Jeep Grand Cherokee with a 318. Any tips for removing the fan assembly from the water pump?
Re: water pump removal [Re: blaze] #2435981
01/16/18 11:06 PM
01/16/18 11:06 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
leave the serpentine belt on---you have to break that big nut on the fan--break it counterclockwise-----there have been numerous how to's here on the ram trucks....
Re: water pump removal [Re: savoy64] #2437160
01/18/18 11:23 PM
01/18/18 11:23 PM
IN
ahy Offline
ahy  Offline
IN
Leave the belt on, put a wrench on the big fan nut and whack it with a hammer in the correct direction method has usually worked for me. The only exception was a 5.7 hemi that had locktight applied to the fan nut at the factory. I had to fabricate a pinned holding tool for that one similar to the factory tool. Then used a wrench. That worked. That particular nut went back on the new WP with anti-seize grease and no issues after.
Re: water pump removal [Re: ahy] #2441890
01/28/18 01:13 AM
01/28/18 01:13 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
X2 on Ahy way big hammer and smack it. Remove dip stick as i broke one when the nut freed up. I take a shop rack to hold wrench in position and wack it. Some guys in the shop will take a air chisel and catch the nut at it edge and move it. FYI most diesel go clockwise to remove.
Install just a good tap of the wrench will do it.
Re: water pump removal [Re: blaze] #2444933
02/01/18 11:32 PM
02/01/18 11:32 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I only used my air chisel at an angle on the nut flat.One or 2 burps and it loose.Then just spin it off by hand.Its a regular thread so it left loose.Remove the AC compressor if its like a Dodge.Makes it easy to remove the stat if you chage it.The pipe off the pump can be tough to remove sometimes.The hose from the intake can be a bear to get to the clamp sometimes also.Rocky
Chrysler Firepower
