Ignition timing over heating? #2435842
01/16/18 07:04 PM
01/16/18 07:04 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Is it really possible to overheat a Smallblock pretty fast without enough timing? You’d think it wouldn’t run or even be smooth. 2000 rpms it runs hot in 5 min. I need to get timing tape on it to see where it is. Timing by “feel” isn’t working.
Re: Ignition timing over heating? [Re: da50r] #2435846
01/16/18 07:19 PM
01/16/18 07:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I's start looking elsewhere at the cooling system but you really do need to get the timing correct also.
Re: Ignition timing over heating? [Re: da50r] #2435849
01/16/18 07:22 PM
01/16/18 07:22 PM
hooziewhatsit Offline
It may not be related, but I changed up how my timing works, and mine seems to run a lot cooler on the highway now.
If you ever find yourself in a fair fight, your tactics suck.
Re: Ignition timing over heating? [Re: da50r] #2435852
01/16/18 07:38 PM
01/16/18 07:38 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Or get a dial back timing light and forget the tape.
Re: Ignition timing over heating? [Re: da50r] #2437774
01/20/18 01:10 AM
01/20/18 01:10 AM
RapidRobert Offline
RapidRobert  Offline
0.0632683" is (1) degree. measure out a strip of paper for how many degrees you need. IE 2&1/4" (2.246") is 35.5 degrees. How hot is "hot" Confirmed with a good mech gauge? is this a new ring breakin? I'd think 30 deg (1.898") at 2000 RPM would be enough to keep it from overheating from retarded timing.
Re: Ignition timing over heating? [Re: da50r] #2437799
01/20/18 02:19 AM
01/20/18 02:19 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
YES. I think alot of old cars overheat because their owners won't check the timing or don't set it correctly. When its too retarded more of the bore is exposed to more flame front, and you get more heat transfer into the coolant.
Vacuum advance helps too. With stock type timing curves removing the vacuum advance will often cause them to run hot.
Now I need to pin those needles, got to feel that heat
Hear my motor screamin while I'm tearin up the street
Re: Ignition timing over heating? [Re: da50r] #2437827
01/20/18 03:48 AM
01/20/18 03:48 AM
To little as well as to much total timing will make motors run hotter than when there tuned properly scope
Do you have access, beg, borrow or rent, to a dial back timing light? If so get it and let us know if you need help on how to use it to set your timing correctly thumbs
Re: Ignition timing over heating? [Re: da50r] #2438183
01/20/18 11:51 PM
01/20/18 11:51 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
and to add to what was said, too little timing can feel smooth.
