Re: Exhaust leak ??
[Re: Jupiter331]
#2435833
01/16/18 06:47 PM
01/16/18 06:47 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Are You Using Exhaust Manifold Gaskets ?
The Fel Pro Exhaust Gaskets That Everyone Uses , Will Burn Out Or Leak Overtime , Especially If Your Manifolds Are Warped
I Finally Had Both Of My Original Exhaust Manifolds Planed At The Local Machine Shop
RemFlex Makes A Nice Manifold Gasket
Why Not Fix The Exhaust Leak First By Pulling The Manifold , Then Go From There
Also It Could Bee Leaking From Where The Header Pipe Attaches To The Exhaust Manifold
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
Re: Exhaust leak ??
[Re: Jupiter331]
#2438336
01/21/18 12:30 PM
01/21/18 12:30 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Dribble a small amount of atf down the carb with the engine at a fast idle. Watch for smoke from where the leak is.
Re: Exhaust leak ??
[Re: Spaceman Spiff]
#2438359
01/21/18 01:09 PM
01/21/18 01:09 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
My experience has been the forward most stud will brake. Seen a lot of this. The bolt stays in place due to it's long association with the connecting parts, makes it hard to notice. Your memory is fine Gene, the heat riser is on the drivers side and can also cause these symptoms.
Re: Exhaust leak ??
[Re: Jupiter331]
#2438365
01/21/18 01:15 PM
01/21/18 01:15 PM
Posts: 3,462 Back in NJ....
EWJ
Back in NJ....
Also the choke stove can leak.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Exhaust leak ??
[Re: Jupiter331]
#2438377
01/21/18 01:27 PM
01/21/18 01:27 PM
I do hear a hissing sound from the passenger side if I click the motor over without starting it. Any thoughts? I'd disable the ign & crank it & see if you an pin it down with the stethoscope or heater hose. You might spray some dish soap/water in there & see what bubbles up & I'd try it with no ign then if no results start it & see if you see anything & I'd do it cold so the heat doesn't vaporize the liquid & make diagnosing this more difficult. they say exhaust leaks and some types of valvetrain noises sound incredibly similar. Holler how it turns out.
Re: Exhaust leak ??
[Re: smos001]
#2438563
01/21/18 07:45 PM
01/21/18 07:45 PM
Good reminder as I have one of those CO meters & I am gonna dig it out to confirm my head gasket issue is resolved (& I will keep it away from the tailpipe(s).
Re: Exhaust leak ??
[Re: Jupiter331]
#2438801
01/22/18 12:56 AM
01/22/18 12:56 AM
Posts: 2,487 God's Country Maryland
GODSCOUNTRY340
If you're hearing a hissing sound while cranking it over I'd say you've got a blown head gasket. The exhaust system will not build up enough pressure by just cranking it over for it to be an exhaust system leak.
Re: Exhaust leak ??
[Re: Jupiter331]
#2438914
01/22/18 11:38 AM
01/22/18 11:38 AM
Posts: 6,363 Abilene, Texas
fastmark
Abilene, Texas
Just had this problem. It was a warped exhaust manifold. Check that first with a straight edge. Use the heater hose trick. It works like a stethoscope. Next I would try a leak down test. That will find a blown head gasket.
