Im needing to know other then heads aside whats the most lift with a hydro roller the oem hydro-dogbone setup can take in a la roller block? It would be with new oem lifters.
Its a reground la roller that had a hair off the base circle when ground and has a .538 ex lift although id expect it to be a hair less with the pushrod angle.
Cam should be done about 6k.
Thanks.
