Removing paint from dash pad
#2435236
01/15/18 09:47 PM
01/15/18 09:47 PM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
What's the best way to remove paint overspray on a dash pad? My dash pad is covered in overspray from when it was at the body shop and I've tried a clay bar so far and lots of scrubbing with other cleaners but nothings touching it. I've heard of people using brake cleaner, but I'm not sure if it's safe for the dash. Is there anything else that works?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Removing paint from dash pad
[Re: 73cuda340]
#2435510
01/16/18 11:02 AM
01/16/18 11:02 AM
Posts: 4,916 new berlin wisconsin
Mr T2U
i would use acrylic enamel reducer before trying lacquer thinner. reducer is not as strong of a solvent. don't use reducers designed for urethane paint, they are almost as strong as thinner. fingernail polish remover is almost the same as enamel reducer.
perception is 90% of reality
[Re: 73cuda340]
#2435533
01/16/18 11:47 AM
01/16/18 11:47 AM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
Most solvents will damage the vinyl. I had luck at removing paint from dash pads using an "environmentally friendly" paint stripper. I don't recall the brand but I think I found it at Home Depot.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: Stanton]
#2437640
01/19/18 08:19 PM
01/19/18 08:19 PM
73cuda340
clarks summit pa
Ok thanks, Ill try the spray nine.
[Re: 73cuda340]
#2438123
01/20/18 09:30 PM
01/20/18 09:30 PM
Posts: 5,774 ohio
ruderunner
ohio
Are you in a hurry? The plastic in a dash pad will leach it's own solevent which will lift the paint as well.
How long will it take? 6 month to 20 years.
I suggest waiting as long as possible then using the least potent solevent and brush as possible. I like kerosene.
Angry white pureblood male
