Creating a 4 speed TA transmission #2434260
01/14/18 03:31 AM
01/14/18 03:31 AM
Michigan, USA
sixpackman Offline OP
Michigan, USA
Hello,
I have an AAR with a incorrect 4 speed trans. Looking for/ create a TA trans. I know the gears are different but the one question I have is the front bearing. Is it suppose to have the big or small bearing to be correct?
Any help would be greatly appreciated.
Thanks in advance.
Re: Creating a 4 speed TA transmission [Re: sixpackman] #2434264
01/14/18 03:49 AM
01/14/18 03:49 AM
All of the 1971 and up non overdrive NP 833 23 spline tranny have the same gear ratio as the 1970 AAR and T/A had scope
As far as the front bearings in them I think they where all the smaller 23 spline ones, not like the big hemi bearing and definitely not as big as the later O/D. tranny have scope twocents
Re: Creating a 4 speed TA transmission [Re: sixpackman] #2434557
01/14/18 06:45 PM
01/14/18 06:45 PM
Michigan, USA
Michigan, USA
How would I know which trans I have? Is there a specific part number I need to look at to tell me if I have a post 71 trans that has the correct gearing?
I'm having the same issue with the heads on my AAR. I have 915 heads but some are 1.88 and some are 2.02 with offset rockers. The 915 heads have a "A" thru "E" after it? Been trying to figure out how to differentiate between the too. Heads are on my current motor so I cant see the valves.
Re: Creating a 4 speed TA transmission [Re: sixpackman] #2434563
01/14/18 06:58 PM
01/14/18 06:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Check the partial VIN on your box, there is a date code there on the same pad also. A photo would help.
Measure the front bearing retainer to determine small block or big block.
915 castings all start out the same & then......
Some are built with small valves, some large & some were offset drilled for the intake pushrods for the AARs & T/As.
Post a photo of your heads with the valve covers off too if you want.
Re: Creating a 4 speed TA transmission [Re: sixpackman] #2434710
01/14/18 11:35 PM
01/14/18 11:35 PM
On the tranny gear ratio you can put the trans in first gear and mark the input and output shafts and tranny case so you can turn the input shaft and count the amount of turns it takes it to rotate the output shaft one complete revolution, if it takes a little over 2.5 turns it has the 2.66 low gear, if it rotates a little less than 2.5 full turns it has the 2.42 low gear scope
As far as all the original AAR and T/A heads and blocks the heads have the intake pushrod holes move over away from the stock location and all of them have to use offset adjustable rocker arms, they came with them stock with ductile iron adjustable rocker arms and matching pushrods, same cam and lifters as the stock 1970 340 motors had but different rockers and pushrods scope None of them came with the small valve heads, they should be either O or U castings, maybe even some J castings but maybe not on that last one confused
IHTHs thumbs
