Re: 1968 B Body upper cowl removal
[Re: VegasCharger]
#2434089
01/13/18 08:48 PM
01/13/18 08:48 PM
Posts: 953 Chicago
PurpleBeeper
Chicago
I HAVE NEVER DONE THAT JOB.... just saying, but if you're SURE it's lead, then "maybe" you could melt it out with a propane torch & not warp the metal? I would be afraid to use any torch hotter than that.
Lead melts at 612 F Steel (s) melt at 1400+ F, but I bet a panel will warp at a lower temp
440+6, NOS, 4-spd, SS springs
[Re: VegasCharger]
#2434095
01/13/18 08:55 PM
01/13/18 08:55 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I would think a hardware store bottle of propane would melt that lead easy enough, if you don't have an oxy/acetylene set-up. Wear a mask/respirator, as lead is nasty stuff. As with anything take your time and do a little at a time. I own a 68 B-body and would appreciate updates to this process. Good Luck!
[Re: VegasCharger]
#2434160
01/13/18 11:12 PM
01/13/18 11:12 PM
Posts: 8,828 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Wear a mask/respirator, as lead is nasty stuff. This is only an issue if you're grinding the stuff. Melting it is not an issue.
[Re: VegasCharger]
#2434349
01/14/18 12:22 PM
01/14/18 12:22 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Not necessarily. Burning paint and melting lead do put off fumes that aren't lung friendly. Well I suppose if you toke the stuff regularly it'll eventually kill you, so yeah, you're right.
