Re: Coning along
[Re: Mr.Yuck]
#2433418
01/12/18 03:16 PM
01/12/18 03:16 PM
Posts: 9,815 MI, usa
dvw
MI, usa
The heads were done because of NHRA rules I believe. The ports have been moved and raised. This is a former members engine. It was designed to run 9's. The car is all steel, so I suspect it will be close to 3200 w/ driver and gas. It could probably run 9's on "pump gas". I'm just going to take it easy.... Looks good, but 3200 with driver? Not without a lot of gutting and light pieces. More like 3500-3700. Doug
Re: Coning along
[Re: BradH]
#2433489
01/12/18 04:48 PM
01/12/18 04:48 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Not enough dumb comments...yet
Brookeville, Md
The heads were done because of NHRA rules I believe. The ports have been moved and raised. This is a former members engine. It was designed to run 9's. The car is all steel, so I suspect it will be close to 3200 w/ driver and gas. It could probably run 9's on "pump gas". I'm just going to take it easy.... Quick history lesson: 1. The castings were mine, originally... had an uncommon feature of CNC chambers, although the ports were as cast. 2. Another member bought them and provided them to the group from Moparts that entered the Engine Masters competition... 2003, IIRC. I believe four different people had their hands on those heads to complete the work. The only one who still posts here on any regular basis is Dwayne Porter. 3. Jim Hanrahan "440Jim" bought them and ran them on his A-body bracket car before going "big" with a new engine and switching to E85 fuel. Any alcohol in the fuel will turn all that epoxy to sh!t. 4. I knew Chris bought them, but didn't know if he ever used them. The last pictures I'd seen of them did not show the additional floor "wing". I don't know if those were used on all of the ports, or only certain ports, or... ? They aren't part of the original epoxy fill to raise the ports. yes they were 440Jims heads the entire motor was his. Chris Bought it to use in one of his cars but went a different route. I guess I'll have to find a place that sells 93 non-ethanol gas or just use 110. In any event it should run pretty good I think.
Re: Coning along
[Re: dvw]
#2433490
01/12/18 04:50 PM
01/12/18 04:50 PM
Mr.Yuck
Brookeville, Md
The heads were done because of NHRA rules I believe. The ports have been moved and raised. This is a former members engine. It was designed to run 9's. The car is all steel, so I suspect it will be close to 3200 w/ driver and gas. It could probably run 9's on "pump gas". I'm just going to take it easy.... Looks good, but 3200 with driver? Not without a lot of gutting and light pieces. More like 3500-3700. Doug could be.. not sure. hood and deck lid are heavy. But a lot of the floor and trunk is sheet metal....no heater box, man steering and such.
Re: Coning along
[Re: ccdave]
#2433933
01/13/18 03:23 PM
01/13/18 03:23 PM
Mr.Yuck
Brookeville, Md
That red is outstanding Is that E5 red? Viper Red, a member painted the car and sold it to me. it is really nice.
Re: Coning along
[Re: Mr.Yuck]
#2433938
01/13/18 03:43 PM
01/13/18 03:43 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
Sounds like a Moparts car for sure. Seems a lot of members have had a hand in it. Kinda cool..
