"70 Cuda ECS #2432466
01/10/18 09:49 PM
01/10/18 09:49 PM
N. Ca.
floorit426 Offline OP
N. Ca.
Hi,
I'm planning on restoring my fuel system. It is a California car, with ECS (or at least it once did). I see that restoration lines are available, but is the vapor tower (I think that's what it's called), the capped off pipe that is located on the right side of the trunk?
Re: "70 Cuda ECS [Re: floorit426] #2432517
01/10/18 11:12 PM
01/10/18 11:12 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The system requires:
Vapor Lines
3 nipple valve cover breather
ECS fuel tank
ECS fuel filler neck
ECS gas tank
ECS Vapor Separator
Carb with bowl vent to nipple (not atmosphere)
Shielding for vapor lines
ECS Vapor Separator is not a reproduced item but I am sure I have a used one if needed.
Re: "70 Cuda ECS [Re: Morty426] #2432597
01/11/18 01:13 AM
01/11/18 01:13 AM
N. Ca.
N. Ca.
pm sent
Re: "70 Cuda ECS [Re: floorit426] #2432703
01/11/18 09:38 AM
01/11/18 09:38 AM
MA
steve70 Offline
steve70  Offline
MA
Here are a couple pictures of a ECS 70 Challenger
1970 Challenger T/A 4 speed
Re: "70 Cuda ECS [Re: floorit426] #2432704
01/11/18 09:39 AM
01/11/18 09:39 AM
MA
steve70 Offline
steve70  Offline
MA
shield and gas cap
Re: "70 Cuda ECS [Re: steve70] #2432750
01/11/18 11:56 AM
01/11/18 11:56 AM
N. Ca.
N. Ca.
Thank, those help, a lot. I guess, in addition to the separator, I will need that shield. Are those repopped?
Re: "70 Cuda ECS [Re: floorit426] #2432755
01/11/18 12:17 PM
01/11/18 12:17 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Not sure if they are and they are different between 70 and 71.
Re: "70 Cuda ECS [Re: floorit426] #2432847
01/11/18 03:56 PM
01/11/18 03:56 PM
Sharpsburg Maryland
440farmer Offline
440farmer  Offline
Sharpsburg Maryland
Does anyone have pics of a 71 the hoses come out in the front of the tank??
Re: "70 Cuda ECS [Re: floorit426] #2432859
01/11/18 04:18 PM
01/11/18 04:18 PM
Western Colorado High Desert
moparmarks Online penguin-006
moparmarks  Online Penguin-006
Cuda won't have the fill tube with the nipple. That was Challenger only.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, .
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: "70 Cuda ECS [Re: 440farmer] #2432860
01/11/18 04:19 PM
01/11/18 04:19 PM
71 the 4 nipples are on the pass side. 72 they are in the front.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: "70 Cuda ECS [Re: floorit426] #2432874
01/11/18 04:49 PM
01/11/18 04:49 PM
Sharpsburg Maryland
440farmer Offline
440farmer  Offline
Sharpsburg Maryland
Mine are on the front I was thinking its going to be a pain in the azz to get those crimp clamps on
Re: "70 Cuda ECS [Re: 440farmer] #2433180
01/12/18 01:47 AM
01/12/18 01:47 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
No 71 E body has hose nipples on the front of the tank. There is only 2 tanks for a 71 E - cuda or Challenger
Re: "70 Cuda ECS [Re: moparmarks] #2433182
01/12/18 01:49 AM
01/12/18 01:49 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Thanks - I couldn't remember and thought that was the case but all my stuff is 7000 miles away right now
