Re: 1982 5th Avenue quit running, will not crank [Re: nd65] #2438369
01/21/18 01:17 PM
01/21/18 01:17 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Could it be the keyed switch itself?
I had one go bad on my pick-up.
Would act up occasionally for awhile then finally quit altogether.
I have mechanical Aptitude.
I can screw up anything.
Re: 1982 5th Avenue quit running, will not crank [Re: RapidRobert] #2442305
01/28/18 04:37 PM
01/28/18 04:37 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
UPDATE.
My son took it to a shop. They found a bare wire touching a valve cover. Even though my son had replaced the ignition switch on the steering column, they put on anther one. She fired right up.
Thanks for everyone's help. You guys are the greatest.
