Looking for Photo, PS Return Line W/Markings #2431815
01/09/18 08:56 PM
01/09/18 08:56 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
I'm looking for a good pic of an original PS Return line that shows markings, preferably dated in 69 but 68 through 70 would be helpful.
Thanks in advance.
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2434185
01/14/18 12:08 AM
01/14/18 12:08 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
bump
Nobody?
Hard to believe
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2434294
01/14/18 07:24 AM
01/14/18 07:24 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I have a pump and a hose but I am not 100% sure of it's origin.
Do you have an idea as to the date code format?
It has a cooler that is dated if that might help establish dating
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2434395
01/14/18 01:42 PM
01/14/18 01:42 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
The only thing I currently have to go on is the reproduction hoses being sold that carry "EB V D DDMMY" In these examples all letter/numbers are the same size
The reason for my question is I have my original fuel hose, and the EB is clearly a different size that the date code. Granted its a fuel Vs a PS line but it appears suspect that the same company stamping hoses would change font size for one type of line Vs another. If I'm going to make myself a PS line I'd prefer to have it about as correct as I can.
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2434642
01/14/18 10:19 PM
01/14/18 10:19 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Well I'll gladly post a pic of what I have but you'll have to wait until the end of the week and you might have to remind me.
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2434683
01/14/18 11:02 PM
01/14/18 11:02 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Much appreciated if you can help
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2434722
01/14/18 11:50 PM
01/14/18 11:50 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Well ,not much of a response for you so I'll add some info...As you've already stated the repop hoses sometimes make no attempt at accuracy and more of a plain old money grab in the name of "correctness" when the product couldn't be more from the truth...The trouble is without documentation and investigation one wouldn't know which parts are suspect of being a generic version of the real deal...But, FWIW..The 6bbl display at Carlisle a few years back did in fact have the larger "V" font as you've suspected...Here's a pic of a current repop and the carlisle display for you...Sorry I can't pull out the date code for you but the larger font clearly can be seen...
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2434731
01/15/18 12:02 AM
01/15/18 12:02 AM
Harrisburg, Pa.
Harrisburg, Pa.
Not trying to steer the thread off course but here's the fuel line detail for your entertainment..Not the "EB" but the "KV" on this one{note the two different fonts}...
Re: Looking for Photo, PS Return Line W/Markings [Re: screamindriver] #2434806
01/15/18 02:26 AM
01/15/18 02:26 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Really appreciate the help, zooming in on that photo its difficult to tell but is the marking "(Large)EB (Smaller)D MMDDY (Large) V" ? So not even the order is the same as the reproduction currently offered?
Is this going to be another case where due to lack of documentation, the reproduction will become the new standard for correctness . . . . Hopefully others will post up if they have originals
Editing for clarity - the Carlisle display is not NOS but perhaps someone took greater care to reproduce what they found on an original hose? This is exactly the reason I'm trying to find original markings. I had what I believe to be original but could find NO markings, but suspect steering fluid/oils may have been a contributor to eliminating them.
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2435082
01/15/18 05:11 PM
01/15/18 05:11 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
So considering the overwhelming response to this topic let me throw out another idea.
The entire reason I've believed the PS return line has markings is based 100% from the reproduction hoses offered today. I have yet to be shown a single survivor return line photo with a marking to support the reproduction is not correct or correct. Very strange for this community and feeling a bit like a snipe hunt.
Is it possible that PS return lines had NO MARKING?
Questioning my own though, it makes little sense that a manufacturer would not mark hose, but who knows?!
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2435199
01/15/18 08:55 PM
01/15/18 08:55 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
I would like to kick myself in the
I literally sliced my factory original power steering return hose off my 1971 Bee this past summer when rebuilding my numbers motor and restoring my k member
I thought i saved the damn thing but i cant find it in the garage today
I will says this - Fact it had lettering and numbers , but nothing like i see in these reproductions , not even close - Even had the factory red clamps
But anyways , someone out there has to have some survivor pictures , or NOS Stock
Roger Gibson ?
Tonys Parts
Bill Rolik
I cant find any pictures thru google
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2435241
01/15/18 09:54 PM
01/15/18 09:54 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
I believe my OE return hose is on my engine yet. I will look later tonight. it is a 1969 B Body. (SPD 824) I have shared my EB stampings from the fuel lines with some people.
HEMI,S ARE FOREVER!!!
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2435983
01/16/18 11:10 PM
01/16/18 11:10 PM
Harrisville,PA
GRAYBO Offline
GRAYBO  Offline
Harrisville,PA
AAR#2, here are pics off of my unrestored SBird. Hope it helps. Graybo
Re: Looking for Photo, PS Return Line W/Markings [Re: GRAYBO] #2435987
01/16/18 11:12 PM
01/16/18 11:12 PM
Harrisville,PA
GRAYBO Offline
GRAYBO  Offline
Harrisville,PA
Another pic of my return hose 1970 Bird.
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2436077
01/17/18 01:09 AM
01/17/18 01:09 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Graybo, unsure if its just me but I can't see any of those attachments ??
OK, got them, this is great and supports the reproduction is close, difference being the "V" on the reproduction and on yours theres an "X1"
Thanks for the help, and the first "snipe" sighting.
Any others?
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2436091
01/17/18 01:27 AM
01/17/18 01:27 AM
Harrisville,PA
GRAYBO Offline
GRAYBO  Offline
Harrisville,PA
Any others?
Any others? as in more pics or more input from others?
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2436095
01/17/18 01:29 AM
01/17/18 01:29 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Hopefully we can gather a sample of more than 1, thank you so much for helping.
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2436096
01/17/18 01:31 AM
01/17/18 01:31 AM
Harrisville,PA
GRAYBO Offline
GRAYBO  Offline
Harrisville,PA
Okay got ya. Your more than welcome. Best of luck.
Re: Looking for Photo, PS Return Line W/Markings [Re: AAR#2] #2436589
01/17/18 10:01 PM
01/17/18 10:01 PM
West Central Wi.
West Central Wi.
I cannot post them. my pics are too large?
Re: Looking for Photo, PS Return Line W/Markings [Re: 1969 HEMI R-T] #2436610
01/17/18 11:02 PM
01/17/18 11:02 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Can you take a pic with a cell phone or screen capture??
Or confirm if your's appears like Gray's?
