Steering column sleeve removal
#2431332
01/08/18 10:59 PM
01/08/18 10:59 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Trying to remove the sleeve off a ‘72 b body column and it is not budging. Using a puller but the sleeve is not coming off the spline. I put this sleeve on a few years ago when swapping steering wheels but it’s not wanting come off now. Thoughts?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Steering column sleeve removal
[Re: dfsmopars]
#2431367
01/08/18 11:48 PM
01/08/18 11:48 PM
Posts: 14,889 up yours
Supercuda
put the puller on, put some tension on it, then using a long drift and a hammer hit the sleeve.
